Old 10-06-2010, 12:12 AM   #1
Slammed66
Needs a Big Block
Slammed66's Avatar
PROJECT: The Heap.
After selling my 66 Gmc, in April, I felt the need to have another beater, I wanted another slammed short fleet. Sooo I did the most logical thing and bought a 70 GMC long fleet 3/4 ton.
Soon after getting it running, I swapped in the diff and front suspension from a dead 79.
threw on a set of kijiji found torque thrusts. called it good.
well nothing is ever good enough, soo as youll see About 2 weeks ao I tossed on a 68 chev front clip.
Well that was fun, but HEY itll fit better in the garage as a short box, taking us to this week. Soo Ill post the pics I have and update as I progress.
The Name ?? well that the name my girlfreind gave it when I pointed out my newly found $400 prize on the side of the highway.
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 10-06-2010, 12:26 AM   #2
Slammed66
Needs a Big Block
Slammed66's Avatar
Re: PROJECT: The Heap.
My old 66, fun old truck, built in a week last summer, Now owned by Notch1988 on here.
okay onto the heap, didnt take many pics, just some crappy cell phone pics.
replaced the driver side inner and outter rocker and floor pan.
drove it for a bit, gave it a power polish one night as I was bored.
1964 Short box
1972 K10
Old 10-06-2010, 02:01 AM   #3
Slammed66
Needs a Big Block
Slammed66's Avatar
And now the fun suff.
68 front clip. deeeeecent.
HEAP vs Grinder.............
1964 Short box
1972 K10
Old 10-06-2010, 02:05 AM   #4
Slammed66
Needs a Big Block
Slammed66's Avatar
1964 Short box
1972 K10
Old 10-06-2010, 12:17 PM   #5
brn agn
brn agn's Avatar
Whoa...this is getting good! I'm subscribed.
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 10-07-2010, 01:01 AM   #6
classicchev
classicchev's Avatar
What, you have a garage???
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 10-08-2010, 01:33 AM   #7
Slammed66
Needs a Big Block
Slammed66's Avatar
Yea man, I pony'd up up and became a homo-ner. its cool
I could actualy use your advise. I need to insulated and heat my garage before the snow falls.
My plan is to insulate and vapor barrier, with r 14, i beleive thats all I can do with 2x4 studs.. and forgive me but Im house and wood illieterate.
I was gonna cover the walls with osb instead of dry wall.
same with the roof, and rent the machine from home depot and blow in insulation. would it be better to lay down bats????
1964 Short box
1972 K10
Old 10-08-2010, 09:39 AM   #8
classicchev
Matt,
Pretty much like you said. Use Roxul and you can get a extra couple R value, 6 mil poly, and what ever you want to cover it up.
The machine is fine, make sure you have insulation stops at the eave ends, and blow away. I usually put batts for the first 4 feet one the eaves then blow in the rest of the area. Batts are just a little easier to get into the tight areas, usually from below.
Have fun,
Darren
Old 10-25-2010, 01:45 PM   #9
Slammed66
Needs a Big Block
Slammed66's Avatar
Back from work, Ive just been working on getting the box sides all welded up and finished, then it on to rust repair, I need o do the flanges inside the box. the drivers side floor, passanger side rocker, and all the supposrts, both cab corners. I may end up just getting a better cab, and ill lose the markers that way too. pics later today
1964 Short box
1972 K10
Old 10-25-2010, 06:07 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Great looking project!
Diggin' the old '66!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
