Easy Does It
Brake line size?
could anyone tell me the stock brake line size on these trucks? thanks
![]() Join Date: Nov 2007
Re: Brake line size?
According to the book:
"On 1/2 ton models brake tubing of 3/16" diameter is used for all hydraulic brake pipes except the line between main cylinder and tee fitting on frame right hand side rail which is 1/4". "Excepting the 5/16" rear wheel trunk line and main cylinder to brake booster line on tandem models, all hydraulic lines on all except the 1/2 ton truck are 1/4" brake tubing." I can vouch for the 1965 1/2 ton. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
