10-07-2010, 11:53 PM | #1 |
starter solenoid wires- which goes where?
I recently bought a 72 Chevy c10 with no engine and trans. I am slowly getting it back together with a 30 and 700r4. I can't remember for the life of me which wire go where on the starter solenoid. It has been years since I swapped engines in a truck without an HEI. Since I didn't do the swap, I didn't pull everything, and the P.O. didn't label anything. THere is a yellow and a purple wire...Which goes where on the solenoid ?!?!
10-07-2010, 11:58 PM | #2 |
Grandpa in the rustmobile...
Re: starter solenoid wires- which goes where?
on HEI purple wire goes to terminal closest to block...idk bout yellow wire, thats for coil? i think
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-08-2010, 12:24 AM | #3 |
Yellow to "R" terminal and purple to "S" terminal.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
10-08-2010, 12:14 PM | #4 |
Thanks guys for the quick help. That's two less wires I have to try and figure out!
10-08-2010, 12:34 PM | #5 |
Maybe this will help you figure out a couple more, thanks to member boundstaffpress..... http://farm4.static.flickr.com/3645/...c2a8064d_o.jpg
10-08-2010, 04:27 PM | #6 |
DEFINITELY!!! I thought I was going to have to break down and spend $30 on an assembly manual just for this!
10-08-2010, 04:51 PM | #7 |
Back in the sticks
If I remember correctly, you can do away with the yellow wire altogether. Just need the purple for cranking power. I don't have yellow on either of my rigs and they are both HEI.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
10-08-2010, 05:57 PM | #8 |
its all about the +6 inches
Sounds to me like he does not have HEI.
The S terminal is normally closest to the block, and the R is normally to the outside. But, not always. |
12-10-2010, 10:43 PM | #9 |
I also need some help. Bout fried my wiring harness today. I believe we hooked the yellow and purple both to the inside and it sent power back through the outside harness. Good part is the motor did start. Which wire goes to the new hei dist we installed on my 73 model 454 installed in my 72/67 hybrid - we call her "El Diablo" as she has fought us all the way. Hope to start a build thread next week. HELP an old hillbilly out
12-11-2010, 12:18 AM | #10 | |
Cruzin
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
12-11-2010, 11:50 AM | #11 |
Junior Member
Just to add a little, I ran a wire like you described, but I put an in-line fuse in it.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
12-11-2010, 02:06 PM | #12 |
Cruzin
thanks i forgot that/ i always run fuses on mine to
12-10-2010, 10:57 PM | #13 |
just do what longhorn said those 2 wires to go on the starter
12-11-2010, 02:23 PM | #14 |
Hmm
Po Installed HEI, and its a red wire goig to it, but NO idea where it goes to...?
