10-08-2010, 05:19 PM | #1 |
uh oh. truck started getting the chugs and shakes after i turn it off
i've always seen peoples older cars/trucks do that. i don't wanna turn into "that guy" that people stare at all the time! could my ghetto carb setup be causing it?
10-08-2010, 05:49 PM | #2 |
Re: uh oh. truck started getting the chugs and shakes after i turn it off
My Dad's engine did that. I think it was because his timeing was advanced too much or something.
10-08-2010, 05:55 PM | #3 |
My truck does this when its hot outside and its been running a while.
1984 chevy swb(1st truck, sold..) 2001 RCSB silverado, 5.3 with a little extra 2004 ECSB Silverado LT, 5.3 cam & bolt ons, 4l60e shift kit/stall, g80 & 3.73s My first (1984 c10) Build |
10-08-2010, 06:19 PM | #4 |
Your truck is dieseling, I saw your zip tie rigged carb and would probably start with your carb. Im not the brightest flash light but managed to rebuild my quadrajet and it only cost 25 bucks for the gasket kit. If you decide to rebuild it yourself do plenty of research online, I saw alot of how to video's on youtube.
10-08-2010, 06:21 PM | #5 |
its prob timing if it runs good just shut it of in drive that will kill the engine right away
10-09-2010, 10:38 AM | #6 | |
10-09-2010, 10:50 AM | #7 |
Kid's Mechanic
Timing , sometimes idle speed too high. Vacuum advance not plumbed to a ported vac source............
10-08-2010, 06:51 PM | #8 |
I know my dist. was walking abit over time and I just reset the timing
10-09-2010, 10:33 AM | #9 |
My truck does the same thing. When fuel enters the cylinder, it becomes a vapor, and when your engine heats up (mine runs about 205-210 degrees) I think the hot cylinder walls ignite the fuel vapor, simply because vapor ignites better and quicker than liquid gasoline. And so when you shut the truck off, the pistons come to a stop and allows the fuel vapor that just got squirted in to sit for a split second, and it fires and drives the piston down. Anyone else think so? Just my .02
Rich My first truck!! 1976 Chevy 3/4 ton Camper Special and a 1985 GMC body. Has a 350, 4 BBL Edelbrock, with a Turbo 350, and NP205 T-case. |
