406 Powered
How bad is replacing turn signal switch?
I think i found my brake light problem. How bad is changing the turn signal switch? How much time?
70 GMC 68 c10 2002 silverado 72 4x4 |
![]() Join Date: Jun 2002
Re: How bad is replacing turn signal switch?
Hey, dont know but i am going to try to replace mine so,i hope someone will tell us. Good luck. Buddy
I don't think it is that bad, unless it is a tilt.
72 Cheyenne Super 80 Silverado Blazer 2wd |
Its not bad at all. take your time and it will be fun. give your self all the time you need . pull the wheel and get after it! cheers, Pat
406 Powered
Thnx.......
Really easy compared to anything newer, only "special" tool needed is a steering wheel puller. Doesnt hurt to disconect the battery to keep the horn from blowing in case you ground it. Time wise 1-2 hours is pretty generous time. Good Luck!
Name: Les ---------------------- Couple 80s Couple 70s One 68 ![]() |
DON'T TREAD ON ME
![]() Join Date: May 2005
Been there done that. Steering wheel puller and a couple of hours will have you done.
Old Yeller |
