Old 10-09-2010, 09:31 PM   #1
lrader99
need a rear end
so this C30 i have been looking at is not so good in the cab section. and i dont need another junk cab parts truck...What i do need is the rear end.
I want the narrow dually rear end.
I will end up boxing my C10 frame and slapping that bad boy under my 127" frame and rolling with it. Any one know of a stash pile of such rear ends? What is there specific name? are they Dana 60s or 70's, 12 bolts or 14 bolts....all i know is that its an 8 lug narrowed dually and i want it!
oh and how do i convert my 5 lug C10 front discs to 8 lug discs
lrader99 is offline   Reply With Quote
Old 10-09-2010, 10:21 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: need a rear end
the narrow rear, is actually the same as a normal rear.
The rear in the one ton is the Corperate rear with an eaton diff. We usually call them Eaton HO72 on here.
I don't recomend getting one. a lot of parts are hard to get, like drums.
You can get a 14 bolt rear out of a 73 and newer truck. Any cab/chassis later model truck, or a single rear wheel C/30 will do. (if you don't plan on the heavy loads, then a 3/4 ton will do)
To do the front, the easiest way IMO is the swap out the whole front corssmember, hub to hub, with a c/20 or C/30 truck.
Old 10-10-2010, 09:45 AM   #3
68 TT
Still plays with trucks
68 TT's Avatar
Re: need a rear end
I agree, find yourself a square body C20 and use it as a parts donor for the rear suspension and the front crossmember & suspension.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
