Old 10-10-2010, 04:47 PM   #1
awedel
Electrical class 101!?!?!
Hey guys. I recently found a starter button (2 post) in my garage and I plan on installing it in my blazer instead of the regular ignition ie. Key method. Have any of you guys installed one and what wires/switches will need to be hooked up. The truck is running a mechanical fuel pump
Andrew
awedel is offline   Reply With Quote
Old 10-10-2010, 08:26 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Electrical class 101!?!?!
I would drop this question on the electrical section, those guys really know their stuff. I, on the other hand know nothing
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-10-2010, 11:43 PM   #3
awedel
Great observation! I’m in concurrence.
Old 10-11-2010, 12:00 AM   #4
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Are you going to keep the stock ignition switch in the dash? It also depends on whether you have an automatic(neutral safety switch) or manual transmission. In either case you will use the purple coming off the back of the ignition switch to go to one side of the starter and I think the Pink. I'll have to do some testing to see if it will work like that. You might even get away with just the purple and a ground.
Problem is the on and off function of the ignition switch. Part of it is on, part of it is cranking. If you remove it, you'll have to still complete the ckt somehow.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
