Old 10-11-2010, 11:10 AM   #1
Shaky
Six in a row makes it go...
Shaky's Avatar
Did I install the front sway bar upside down?
Can anybody tell from the pic? Something doesn't seem right...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 10-11-2010, 11:14 AM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Did I install the front sway bar upside down?
not sure... but I don't think it would work upside down?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-11-2010, 12:21 PM   #3
Indyuke
Here's a pic of the factory swaybar in my 70 for reference. It kinda looks like you've got it installed right. It could be that you've got to put the weight back on the wheels to know for sure.
Indyuke is offline   Reply With Quote
Old 10-11-2010, 12:29 PM   #4
70c/10barebone
Junior Member
70c/10barebone's Avatar
It looks correct to me. It seems the angle of the A arm bushing and the tip of the sway bar would be hard to align and tighten down without the weight of the truck on the suspension. That may be why you are having doubts.
70 C/10 LWB 250
70c/10barebone is offline   Reply With Quote
Old 10-11-2010, 12:33 PM   #5
Shaky
Shaky's Avatar
The jack stands are under the lower control arms, however the truck is disassembled - only the drivetrain is on the frame.
It took a little doing to get the last bushing down on the control arm. I had to use a long bolt to drag it down. Maybe I need the entire vehicle weight on the suspension?
Old 10-11-2010, 01:17 PM   #6
OhOneWS6
OhOneWS6's Avatar
Even with the stand under the control arm the suspension is partially un-spring. You would have to have the stand out under the spindle to be the same load as sitting on the tires. That in combination with the body being off you are probably really close to having no load on the suspension at all. Bar looks right to me.
OhOneWS6 is offline   Reply With Quote
Old 10-11-2010, 01:22 PM   #7
ewoody625
ewoody625's Avatar
I had problems with fit/mounting the sway bar I bought from cpp. I called there tech support and they told me it needs to be installed at ride weight so basicly its like the last thing to install, but I think Im still gonna come up short. Have to wait and see when i get to that point like 3 years from now lol.
Eric
70 CST10 long bed in pieces also factory air and cruise(the project)
18 Silverado crew cab 5.3 4x4
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=402166
ewoody625 is offline   Reply With Quote
Old 10-11-2010, 02:41 PM   #8
Shaky
Shaky's Avatar
I think you guys are right - there's just not enough weight on the suspension. Thanks for your help.
