![]() Join Date: Aug 2010
Best Air compressor to Use
Can anyone tell me what air compressor is the best to use. It takes forever for my compressor to get up too 140psi...It takes 140psi to get my front off the ground.
Re: Best Air compressor to Use
Deleted - this is not a shop compressor you are talking about obviously. The "Suspension" forum might get you better responses.
So the York 210 is a air compressor, Volvo???Right? I looked on ebay, not a bad price just have to find a way to set it up.
I would like to spend under $300.00 if possible. I tested my compressor yesterday, I have a 3 gallon that I just put in and it still takes at least 5 minutes to fill. Anyone has ideas on what I can do to speed it up? |
![]() Join Date: Feb 2003
York 210. Fills my 2- 3 gallons tanks to 200 PSI in less than 30 seconds and doesn't make a sound.
Who Me?
I dont think most people are running these, but they do work fast.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Resistance is Futile
Oasis are pretty nice....get ready for a kick in the wallet. I used two Viair 400c's for a couple minute fill time and I'm on my way
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
I agree. I had one on another truck that could fill airbrake tanks that I used in 30 or so seconds. Could also run air tools too!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
