Old 10-13-2010, 11:51 AM   #1
bobcostas
bobcostas's Avatar
Can't get 'er started.
Hey dudes.
I'm just stumped. I can't get my truck started after i made all my modifications. I got a 4-barrel holley and a 4-barrel manifold put on my sbc400, and now she wont start. I probably have the timing so far out of whack, but also it might be the ebay carburetor.
i have the spark plug cables in the right firing order, with the one plug on the drivers side of the HEI coil guy and then clockwise 1-8-6-4...
any tips? anything i probably forgot. Its getting spark and fuel.
thanks guys.
'64 Corvair Ragtop
'66 C10 Stepside
"The oxen may be slow, but the Earth is patient"
bobcostas is offline   Reply With Quote
Old 10-13-2010, 12:01 PM   #2
66redw/white
made in america
66redw/white's Avatar
Re: Can't get 'er started.
if its getting spark and fuel id say it has to be the timing. really what else could it be?
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes.
sounds good
1964 c10-283 powerpack, 3 on the tree
2004 corvette- lowered, borla, tuned. slow
my old girl
1966 c10- 305v8, t-5 sold
66redw/white is offline   Reply With Quote
Old 10-13-2010, 12:10 PM   #3
Bugeyev8
Bugeyev8's Avatar
Originally Posted by bobcostas View Post
Hey dudes.
thanks guys.
firing order is 1 8 4 3 6 5 7 2....
Bugeyev8 is offline   Reply With Quote
Old 10-13-2010, 12:13 PM   #4
bobcostas
bobcostas's Avatar
I just rattled the one i wrote off the top of my head. ill check it again, but im 99% sure its right.
'64 Corvair Ragtop
'66 C10 Stepside
Old 10-13-2010, 12:23 PM   #5
Chris65GMC
Try spraying some starter fluid, if you get popping then your timing should be close enough, if you don't get a popping sound than i would look at the distributer and timing.
-Chris
Chris65GMC is offline   Reply With Quote
Old 10-13-2010, 12:43 PM   #6
steverino66
Make sure you wired in the direction the rotor's spinning (I wired a friend's Olds backwards once)
steverino66 is offline   Reply With Quote
Old 10-13-2010, 12:37 PM   #7
bobcostas
bobcostas's Avatar
i get popping. then i get a fore-fire, which usually scares the bejesus out of me.
'64 Corvair Ragtop
'66 C10 Stepside
Old 10-13-2010, 12:56 PM   #8
bobcostas
bobcostas's Avatar
im beginning to question my carburetor. it was a $40 holley off ebay. it could be boned.
'64 Corvair Ragtop
'66 C10 Stepside
Old 10-13-2010, 01:25 PM   #9
Turkey
Turkey's Avatar
Timing will trump the carb
Turkey is offline   Reply With Quote
Old 10-13-2010, 02:05 PM   #10
66redw/white
made in america
you could have it 180 out if its doin the whole fireball thing
sounds good
my old girl
Old 10-13-2010, 03:09 PM   #11
az65
az65's Avatar
I'd just find tdc on cylinder 1 and make sure the rotor is pointing where the number 1 plug wire goes to. I'm betting you're 180 out
'65 long-bed with 327/3spd
'05 SRT-10 quadcab
'69 Superbee clone
'66 Charger w/ 36k og miles
and a handful of bimmers
az65 is offline   Reply With Quote
Old 10-13-2010, 03:16 PM   #12
jchav62
1962 C-10
jchav62's Avatar
180 out...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 10-13-2010, 08:53 PM   #13
65Guy
Well the rotor does not have to point to num 1 cyl. As log ans you have TDC on compression stroke.......start wires on the cap where the rotor button is pointing. Ive dont it more times than i can count with out takeing my shoes off! just my .02 cents.
65Guy is offline   Reply With Quote
Old 10-13-2010, 09:12 PM   #14
Delmo
Delmo's Avatar
Take the driver side valve cover off and turn it over until both valve springs on number one are unsprung. This means both valves are closed and you are at TDC. The timing mark on the balancer should line up with the timing tab. Drop the distributor in with the rotor pointing toward number one spark plug ( or close) and make a mark on the distributor case where the rotor is facing. If the distributor doesn't drop in all the way just get it in don't freak out as long as it's close ( like 1/4 inch from going in). If you bump the starter the rotor will turn and drop in the oil pump slot. Make sure number one plug wire is at the same spot the rotor was when you first dropped in the distributor. Then double check 18436572. Double check 12v at HEI (not on the tach connector). Snug the hold down clamp slightly, turn the distributor so it's some what sraight. Prime the carb with fuel and hit the key.
Delmo is offline   Reply With Quote
Old 10-13-2010, 09:48 PM   #15
bama63
bama63's Avatar
a much more simple way of doing this is to remove number 1 spark plug place your thumb or finger in the spark plug hole and bump the engine a little at a time until you feel the pressure push your finger out of the hole, check your timing marks and using a 5/8 socket rotate the mark to TDC now pop your cap and start your wiring clockwise 18436572 from the nearest wire tower the rotor is pointing toward, if you need to advance the timing move the dizzy counterclockwise or clockwise if you need to retard ohhh and dont forget to reinstall your spark plug hope this helps
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 10-13-2010, 10:07 PM   #16
Delmo
Delmo's Avatar
Ya I've done it that way too. Takes 5 seconds to pull the cover then you're 100%. I'd be more inclined to crack a plug I guess. Lol
Old 10-14-2010, 05:59 PM   #17
bobcostas
bobcostas's Avatar
Dudes. You're awesome.
Just got the beast started. Delmo, your method was spot on. Thanks a ton.
Now I gotta get it to a muffler shop for a new exhaust. Would y'all discourage driving it a few miles with only headers? will I burn up a valve or two? Because that would be no bueno.
~CR
'64 Corvair Ragtop
'66 C10 Stepside
Old 10-15-2010, 12:14 AM   #18
Delmo
Delmo's Avatar
Glad it worked out for ya, keep the heel to the steel.
