Old 10-13-2010, 12:08 PM   #1
brossow
Amateur Rust Fighter
brossow's Avatar
Question Specs for bed bolts ('79 SWB)?
Wondering if someone can tell me the specs (length and diameter) for the carriage bolts used to attach the bed on my '79 shortbed 2WD fleetside. I'm sure I could figure it out with measuring and trial and error, but it would be great if I didn't have to do that and could just buy what I need the first time. Bed wasn't attached when I bought it and although I don't plan to drive it immediately, it'd be nice to have the bed bolted down when I do.
Found a bolt kit on eBay, but no way am I paying $25 for eight carriage bolts that I can buy in bulk locally for $4/lb! (Especially when it appears two in that kit on eBay are far too short, based on the diagram at LMC:
and an old eBay auction:
Thanks a ton (or at least a half-ton),
Brent
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline   Reply With Quote
Old 10-13-2010, 03:59 PM   #2
Buick455
Re: Specs for bed bolts ('79 SWB)?
Just guessing they are probably grade 5 bolts but I am not sure the size. If they are grade 5 there should be 3 lines on the top of the head. You can buy them from a good fastener business. We have one locally that I buy most of my hardware from.
Buick455 is offline   Reply With Quote
Old 10-13-2010, 04:06 PM   #3
brossow
brossow's Avatar
Thanks, but what I'm looking for are the dimensions -- diameter and length. They look like 1/2" diameter, but length? I'm sure Grade 5 is right.
Brent
Old 10-13-2010, 08:06 PM   #4
54Caddy
GM Addicted
54Caddy's Avatar
well are the bolts on the truck as of now, if it was me id take them off and go down and match them all up nothing hard about it only unless the cariage bolt starts to spin then it can be a pain, and when you find out let me know ahaha because someone put standard bolts in my truck and i hate them.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 10-13-2010, 08:21 PM   #5
85gmcguy
Plays with trucks
85gmcguy's Avatar
I used 1/2-13 x 4 stainless on mine. You really don't have to use the longer bolts they picture, you just have to wiggle a little more to get nuts on the shorter ones. If you have access to Grainger, their part number is 1VE38. Be sure to get stainless washers and nuts, too.
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 10-13-2010, 08:40 PM   #6
brossow
brossow's Avatar
Like I said, the bed wasn't attached when I bought the truck. It's just resting on the frame right now. That's why I need to get it bolted down.
Thanks for the info! Any idea how long the longer ones are, if I was so inclined?
Brent
Old 10-13-2010, 08:41 PM   #7
babyJay
Arrived on a Pale Horse
babyJay's Avatar
I agree with Gary on the stainless, just because I've never managed to get stock ones out in one piece. We usually have to grind off the heads or cut the bottom to get 'em to cooperate.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 10-13-2010, 08:43 PM   #8
brossow
brossow's Avatar
No doubt. After my experience with the teardown on my '72, nothing I build is ever getting assembled with anything but stainless.
Brent
Old 10-13-2010, 09:51 PM   #9
bigblock73
yeller
bigblock73's Avatar
I used to be into stainless this and that, but then I started thinking...I'd have a hardware store nut and bolt truck. No thanks. I actually prefer GM automotive fasteners wherever possible, they look so much better IMO.
On the bolts pictured, I would be worried the square head is the wrong size, and the threads aren't tapered on the end like the GM ones are (easier to install).
I know...I am anal.
bigblock73 is offline   Reply With Quote
Old 10-13-2010, 10:29 PM   #10
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
I know...I am anal.
Also the commercially available carriage bolts do not match the stock bolts. The stock bolt head is slightly larger, both in diameter and dome, and the square is much larger and more robust. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 10-13-2010, 10:35 PM   #11
brossow
brossow's Avatar
Okay, then where does one find stock-spec bolts? I'm not looking for a 100-point resto but just something to keep the bed from falling off the frame.
Brent
Old 10-14-2010, 05:32 PM   #12
85gmcguy
Plays with trucks
85gmcguy's Avatar
Mine only had 1 long 1, and it's about 10 1/2". I still have the ones I removed, they're all in good shape w/nuts. If you're interested, drop me a PM.
Gary
My Dad's Old Truck
1985
