Old 10-13-2010, 04:45 PM   #1
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Help my uncle id his truck and motor
vin#4c144161xxxx
Its a 64 short step with a big rear window
He is pretty sure he has a 327 motor but would like some specs and to know for sure.( passenger side front of block)
Engine ID# F0526 SD
Any info???
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 10-13-2010, 05:27 PM   #2
jocko
jocko's Avatar
Re: Help my uncle id his truck and motor
vin#4c144161xxxx = 4=1964 / C=2 wheel drive / 14= half ton 115" wheelbase / 4=pickup (after the last "4" there should be a letter which will ID the assembly plant location in the U.S. - a "1" (your case) indicates Oshawa, Canada assembly plant - then 61XXXX etc would be the sequential assembly number.
(so, good news, you know you have an original 1/2 ton shortbed - you now know it hasn't been a cab swap victim - not that there's anything wrong with that, just nice to know on one's own truck if it's ever happened) - you can also cross match the truck VIN tag with the VIN stamped into the front left frame rail - can usually make it out by leaning over the left front fender and looking down at the top of the frame rail near the steering box area, etc. You also know it was originally a Canadian plant built truck.
Truck 327 not available in 64 - first year in trucks was 66.
But you do have a 327 - and appears you have a very SWEET one...
Engine ID# F0526 SD = F=Flint (motor plant) / built on May 26 / SD=1962 vette 327 (originally equipped with a powerglide, special hi perf engine - 350hp, 4 bbl carb).
Hope that helps. Wish I could buy a truck and then find out that's what was in it! Nice truck - 64 short step with a big window and a 62 vette 327... I'd hang onto that puppy...
Old 10-13-2010, 05:36 PM   #3
raycow
You will need the casting date to positively identify the engine. SD in 1962 was 300 hp. The first year for 350 hp was 65. I am guessing the SD code was used for more than one year.
Ray
raycow is offline   Reply With Quote
Old 10-13-2010, 05:48 PM   #4
Cole Trickle
C-10 Club Member
Thanks for the info.....
Where might we find out the hear that SD code matches up?
Its a nice solid truck that we found on the local CL
He has since cleaned it up a bunch and added CPP 3.5/4" drop and power disc up front
Old 10-13-2010, 05:50 PM   #5
jocko
jocko's Avatar
raycow - excellent point, I agree (350 hp not available yet).
here's the ref I used for this:
http://www.nastyz28.com/gm-chevy-cod...s-suffix-6.php
and I have used in the past. Now I'm wondering just how valid it is...
thanks for pointing out raycow.
Cole - you may want to cross-check that engine code with a different source. the link above states 350 hp 327 (in 1962) but I believe raycow is absolutely correct - that was not available yet. 62 327's were available with 250hp, 300hp, and 340 hp in the carb'ed version and 360hp for the fuelie (referenced elsewhere, not the above link and the above link matches these numbers at least)- but no 350 hp 4 bbl version. so maybe it's just the wrong hp number in the link's chart above - or maybe it's got a different meaning altogether. sorry maybe slightly bum gouge on the eng id.
Old 10-13-2010, 05:54 PM   #6
Clyde65
Clyde65's Avatar
Wow, nice truck!
Does anyone know if the BBW and stepside bed is common or rare?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-14-2010, 12:07 PM   #7
Cole Trickle
C-10 Club Member
Ray
He was able to get the ID # off the back of the block (drivers side rear of block)
#3782870
Anyother info would be great......he is debating if he should keep this or the built 383 he has laying around.
Old 10-14-2010, 04:41 PM   #8
jocko
jocko's Avatar
3782870 = 62 -67 327 cu in - block used for 250-375 hp, 2-Bolt mains/Truck/Pass
So, combining this with the 'SD' - would appear to be a 1962 300hp 327 block. I think that's a safe bet.
A less safe bet is what it came out of. I've got one ref that says SD was a vette motor - but that was also the ref that said it was (incorrectly) a 350hp motor - so take the vette part with a grain of salt also. I believe 300hp 327s were also available in 'full size' cars in 62 (i.e. impala, bel air, biscayne).
hope that helps.
Old 10-13-2010, 05:29 PM   #9
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Good score on the 327!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-15-2010, 05:49 AM   #10
63sbssbbw
UCA63
63sbssbbw's Avatar
Sweet looking truck CT
I guess the next logical Q on the motor would be,Does it the have the 327 heads on it?
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 10-15-2010, 01:51 PM   #11
Cole Trickle
C-10 Club Member
T
Looks like he has truck heads offf a 1968....
Good news is they seem to be pretty good heads but by no means is this a numbers matching 327.
3947040....68......327.........."Right angle" casting identifier, 64cc chambers, good HP head, used in trucks, no accessory holes
