10-14-2010, 07:49 PM | #1 |
another what do ya think it will run post
Well Its been a LONG haul on this project. At first I was going to just throw a little motor at my long bed c20 and call it good. Then one thing led to another and and now its shortened, lowered 4in frame has been boxed all the factory cross members are gone and replaced with 2"od mild steel round tube, and thats just a start. I've been workin on tis thing for about 3 years and am prob within a year of being able to drive it again, so I've gotta ask what do you think it would run. Here's the specs
lq4 with the gm "hot cam" factory injection (execpt injectors) 88mm garret turbo not exactly sure on hp but it should be somehwere around 575-600 athe the crank engines set back 4" from factory location turbo 400 with brake and manual valve body 8" tci converter with 3500 rpm stall 9" with 3.54 gears and detroit locker fatman front axle with qa-1 ajustable coil overs glass hood and no heater or ac 4in drop monos in back with qa-1 ajustable shocks and caltracks mt street ets 275/50-15 not 100% on the weight bias but it should weight about 3200-3300lbs without me in it so figure 3500lbs with me in it and assuming it actually hooks
1970 c20 converted to c10 sleeper 1979 c20 the wood hauler 1991 honda civic daily driver spray and pray baby |
10-16-2010, 10:36 AM | #2 |
Registered Truck Offender
Re: another what do ya think it will run post
Best I can guess is your gonna need a roll bar ;-)
If it runs to it's potential right out of the box, you just might be the FIRST to do that. Get some passes and you'll have a starting point. Traction and boost is always a balancing game. Short times are going to be key IMO
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
10-18-2010, 12:25 PM | #3 | |
Boosted Member
I am going to say with a good amount of confidence that your rig will run well into the 10s. I'm gonna throw out 10.6X as a SWAG. Keep us updated! Pics?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
10-18-2010, 01:09 PM | #4 |
motor exploder
Once you get it all dialed in, mid to high 10's should be about right. I'm interested in seeing some pics of all that frame fabrication.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
10-18-2010, 10:05 PM | #5 |
i say 11.55 easing it out of the hole
10-18-2010, 10:41 PM | #6 |
Boosted Member
Man, I saw a 67 C-10 shortbed run 11.0 @ 119 on a MPT70 on a 5.3L last weekend...at 10 psi. Turbo 400, decent converter, leaving off the footbrake and 2-step.
More cubes...more turbo....that thing is gonna haul.
10-19-2010, 08:27 AM | #7 |
was it an old red........................farm truck
