ridetech tri 4 link
I purchased a 4 link from ridetech to go in my 57 and I dont know if u weld it to the inside part of the frame or outside. I cant find any pictures of the kit installed. Also do the shockwaves need to be straight up or can they be angled? Any help would be greatly appreciated.
Yellow truck club
Re: ridetech tri 4 link
I think you can go either way. If you go outside you will still have plenty of clearance as well as a bit better ride. I used the ART parallel 4 link from a 88-98 gm in my truck.
Shockwaves can be mounted on an angle as well. You should go over to the ART forum and post your question on there as well. They are on all the time and can help with your questions. found this on their site 6. When the rearend is correctly placed, the lower bracket /bar assembly can be placed. The 4 link kit can be installed with the lower bars under the frame or outside the frame. To determine the proper location, assemble the lower axle bracket, lower bar and the lower frame bracket together and place the lower axle bracket against the axle tube. Assemble the bars with no more than 1/2” of thread showing on the shaft. This will allow for final adjustment. With the lower bar level with the car, determine the best location for the lower frame bracket. Make that decision now because that will determine the side to side location of the lower axle brackets. To place the lower bars under the frame, the lower frame bracket must be trimmed. The “wings” of these brackets will be cut off and the bracket can be placed under the frame. [Be sure to check ground clearance.] 7. When the lower frame bracket location has been determined, tack them into place. [Don’t weld fully yet] 8.
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited Last edited by entourageguy; 10-16-2010 at 05:16 PM. |
Thank you for the info.
Posted via Mobile Device |
By chance do you have a picture of yours installed?
