10-15-2010, 08:49 PM | #1 |
Has more rust than truck...
This shouldn't be this complicated, Horn button
I'm having a heck of a time with my horn button.
Here's what I have. In this pic I'm holding the turn signal cam into the steering wheel adapter with the contact spring and plunger dropped into the hole. Problem is, plunger and spring are no where near long enough to come in contact with the plate the horn button snaps onto. am I missing pieces? Or how do I make this work? Thanks |
10-15-2010, 10:31 PM | #2 |
Its a Truck Thing......
Re: This shouldn't be this complicated, Horn button
I had the same wheel, I wouldnt use that wheel, had my button come loose and the horn went off in the middle of the night, cops woke me up.....I picked up a nice 92 GMC wheel with everything cheaper than the grant wheel and adapter kit.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" Last edited by 71meangreenc10; 10-15-2010 at 10:32 PM. |
10-15-2010, 11:00 PM | #3 |
Grandpa in the rustmobile...
^^ lol what a story..I sorta like the stock wheel look (if in good shape..)
good luck man, thats a nice wheel too!! We dont want your horn to go off at wee hours of the nite
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-16-2010, 11:27 PM | #4 |
Cruzin
i just took a piece of "hard" wire and wrapped the end of the wire in the horn kit and stuck it out about 1/2 in. in a loop and stuck it down in the white thing and ran the wire to the button. clear as mud? and yes these button can pop off and the horn will stay on, had the cops wake me up one night too but my horn got stuck in my stock steering wheel...... and also the plate just grounds into the steering wheel so as long as the wire is touching down in the cylinder and hooked to the brown ring it will work when the horn button is installed with the spring behind it it holds the brown ring up until you push it down were it touches the metal of the steering wheel which completes the ground for the circuit
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
10-16-2010, 11:32 PM | #5 |
Active Member
I did mine with the Grant wood steering wheel and kit. You need to use pieces from the existing horn and the Grant kit. That's the only way I got mine to work and it stays on fine. I should have done a write up but just did it. You need to think it thru, I remember I used the small existing horn contact and cut the Grant piece and made it work. It can be done.
1972 K5 Blazer ALL ORIGINAL paint & engine, A/C, Tilt, 4sp, AM/FM, Tow Hooks, Aux Battery Tray, Tach, Vacuum 2004 FORD FX4 SuperCrew 2005 CTS-V 12 sec family car 2008 Buick Enclave AWD, Nav, & DVD, Wife LOVES it! |
10-17-2010, 12:03 AM | #6 |
Big Red - Now its a SWB!
It has been awhile since I did mine, but I remember that it was a little confusing. If you cant figure it out let me know and I can pull mine apart to figure out how you do it. I do remember that you use some of the original parts like stated above, also a wire connects to the fiber plate but I cant remember where it goes to. Sorry I'm not more help.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
10-17-2010, 01:32 AM | #7 |
Thanks guys, the story about the horn staying on when the button pops off is what made me figure out how it works. Now I just need a spring and a wire to go to the plate. I'll post up with what I figure out. Thanks again
10-17-2010, 09:25 AM | #8 |
I ditched the PO's Grant wheel and re-installed the OEM 17" wheel. After I did it, I was amazed how well it handled with the stock wheel.
10-17-2010, 11:30 PM | #9 |
Back in the sticks
Longhorn man posted a FAQ on this too a while ago. Might look there and see if its still around.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
10-18-2010, 12:40 AM | #10 |
I didn't see that you were missing the wire the first time that I read this, you def. need that. I found this link on how to hook up a horn with pictures of how everything goes together (it's on a jeep, but it is very similar to how you hook it up in our trucks, look at post #11). Hope you get all the parts you need and get it together soon.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 10-18-2010 at 12:43 AM. |
10-18-2010, 01:01 AM | #11 |
Thanks guys. I was missing the wire and the spring. Missing the wire confused me about how the button would complete the circuit and missing the spring just made me think the spring was suppose to go under the plate, not the button. I got it figured out now and will post up when I get it together, still need to get a spring. thanks.
