![]() Join Date: Feb 2008
Date stamped on frame? & What rear end is this?
So my truck is stripped down now and yesterday while priming it, I see
3887701-200 9-12-79 Is that the year the frame was built? Because if it is, I'm now learning my 67 is not sitting on a 67 frame. I was also cleaning up the rear end and was wondering if you can tell me what gears are in here (or were when built) This is on the axle tube HA 09 27 W G86 (hard to read) is on the rear end housing Does that help? Last edited by DrtyJack75; 10-16-2010 at 02:14 PM. |
Re: Date stamped on frame? & What rear end is this?
No one??
Is it a dumb question? LOL |
member #16
![]() Join Date: Dec 1999
HA shows for several years with 1969 the latest. 3.73:1 ratio It is listed for a 1967 C-10
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 10-17-2010 at 05:52 PM. |
awesome...thanks
now how bout the year on the frame?? Help please, Im curious if this is a newer frame |
Six in a row makes it go...
![]() Join Date: Mar 2009
I'm not sure the "79" means "1979". My '67 C20 frame has a "69" in that same location and I'm pretty sure it's the original frame. I don't know for sure though...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
hmm it's just weird.
were the 67's power steering? mine has power steering which dont mean it wasnt added, but it does have little raised nipples where the power steering box is mounted. |
Knuckle Buster, Instructor
![]() Join Date: May 2010
Id love to know if there is a way to decode this info too. My 68 has a 72 in that location. Searching hasnt turned up anything.
Do you have disc brakes? Do you have leaf or coil springs?. No stock 79 would have front drums or rear coils. None of this is bulletproof because a stock 67 could have leaf springs, and disc brakes are a common upgrade.
Ray Last edited by raycow; 10-19-2010 at 08:26 PM. |
drums and coils when I bought it..
so I dont know....I guess it dont matter, just curious! now Disk and Bags... ![]() |
My bad. I meant no stock 79 would have front drums, so I'm guessing you have an original frame. Sorry about the mistake. I will fix that right now.
Ray |
