Old 10-17-2010, 11:19 PM   #1
61apachespeed
hows any one made electric fan shroud??
i guess i have to make one for my 61. i just got a spal fan 2470 cfm. its cooling it just not cooling good. its running 180 and then going down the road it jumps around from 180 to 210. so why does the fan go up high on the rad?? and if anyone has made a electric fan shroud help would be great right now.
61apachespeed is offline   Reply With Quote
Old 10-18-2010, 12:57 AM   #2
QBA
Proud Americano
Re: hows any one made electric fan shroud??
is it a pusher or a puller.is it on constant or thermostatic switch.how is it mounted.
Tattooed Cuban Trailer Trash.
putting the cart before the horse since 1964.
QBA is offline   Reply With Quote
Old 10-18-2010, 01:17 AM   #3
61apachespeed
its a puller on the motor side. its mounted on the radiator core useing metal and the fan sits in the middle of the radiator.
Old 10-18-2010, 10:04 AM   #4
creep
Registered Loser
creep's Avatar
Summit Racing has fairly cheap aluminum shrouds for electric fans.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 10-18-2010, 10:18 AM   #5
nikwho
nikwho's Avatar
So does Jegs. They are slightly different sizes than summits so one may work better than the other for you. Speedway has some universal ones too. You may be able to get a local HVAC or metal working shop in your area that has a brake to make one for you. then you could just cut out the hole for your electric fan. I just got a Jegs universal aluminum radiator and their kit that came with the shroud and fan. Seems pretty nice so far.
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 10-18-2010, 12:13 PM   #6
QBA
Proud Americano
well,as long as its as close to the radiator core as you can get and the fan diameter is the biggest you can get on the radiator core,it should work well.also if its running constant or the thermostatic switch is not the "right" temp range,you will have cooling issues.
speaking from experience.
Old 10-18-2010, 10:22 AM   #7
nikwho
nikwho's Avatar
you would probably need to use a sheet metal brake to make one yourself so you can flare it out on all four sides so it doesn't sit tight against the rad. measure the core of your radiator and see if one of the universal ones can be adapted to fit.
'68 GMC - BBC/TH400
Old 10-18-2010, 10:31 AM   #8
halfcockedcustoms
halfcockedcustoms's Avatar
roaster pans work well too,,not my work,,my club brother Da Tinman
halfcockedcustoms is offline   Reply With Quote
Old 10-18-2010, 12:44 PM   #9
Chris65GMC
This is a great idea!
Chris65GMC is offline   Reply With Quote
Old 10-18-2010, 10:48 AM   #10
nikwho
nikwho's Avatar
VERY creeative!
'68 GMC - BBC/TH400
Old 10-18-2010, 11:10 AM   #11
greg65
greg65's Avatar
Check out Alan's build thread. It has alot of good information in there. Here is a link to the shroud http://67-72chevytrucks.com/vboard/s...248460&page=98
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 10-18-2010, 09:29 PM   #12
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Nothing real fancy, but it should be functional. May have to cut some bypass holes so it will flow going down the road. My engine is moved forward, so I didn't have much room to work with.
Alan's Classic is offline   Reply With Quote
Old 10-18-2010, 10:52 PM   #13
shortbed70
shortbed70's Avatar
yep. Recycled a piece of bed frame or 1"x1" angle welded togather with four holes in each corner and then a piece of 24"x24" galvinized steel folded on the sides 1/2" to make a shallow pan then cut the hole and self tap screwed fan to it then tack weld the shroud to the frame.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 10-18-2010, 10:56 PM   #14
protrash64
Resistance is Futile
protrash64's Avatar
Here's mine. Aluminum with 2 12'' fans. I went with 2 so they would be offset from the waterpump pulley.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
