![]() Join Date: Dec 2009
New to BBC
hey all im new to big block chevys. ive done sbc,lt1,ls1 but this is a whole new animal to me and i would like some help. i want to build a 427 or 454 to power my 71 c10. i would like to see 500rwhp and im going to run this in my daily driver. im using a 6spd trans. i know u guys have some tricks up your sleeves so any advice would help
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted 1997 C3500 DRW Ext cab. 454, 4L80E daily driver |
Re: New to BBC
A good set of heads will be a critical part of the equation. I would go 454 as they are allot easier to come by. If you really want an awesome motor put a 4.25 inch stroke crank in a 454 block and you will be amazed.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Re: New to BBC
not to sound ignorant but what would putting a 4.25 inch stroke crank in a 454 do and what type of heads should i look for
Re: New to BBC
Adding a 1/4 inch of stroke adds several cubic inches. A 30 over is a 489 a 60 over is a 496 and so on.
I have had good luck with Brodix but there are several good heads out there. If you want to race an aluminum head would help allot with weight transfer.
Re: New to BBC
wow ok cool anything else. like i said im new to big block chevy so everything is new to me. what is the best cam setup for the street ex: hyd roller, mechanical, flat tappet, solid
Re: New to BBC
we need to know your budget then go from there. it adds up fast. imo buy one from vortecproengines.com if you only want to spend $5-6000. he is the best out there for the price. check out his reviews on chevelles.com.
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
Re: New to BBC
Hyd roller would be the best but not cheap.
Re: New to BBC
my budget is 4-5k and i know its not alot but im sure with the help u guys have given me i can put something together that will have me grinning ear to ear
Re: New to BBC
With that budget i guarantee you can not beat this deal. Vortechpro... The 468 at 9.1 with 570hp or 620hp for $5k
Re: New to BBC
ripdog i just read ur build thread and i learned a lot and ur truck is absolutely wild. thanks for the link to vortec. that is exactly what im looking for
Re: New to BBC
Thanks for checking it out. Call up mark jones and he will plan it out with you. If I found him before building my engine I would have his 650hp 496.
Re: New to BBC
30 over 4 bolt forgeds crank/rods(7/16th arp bolts) if not h beam or i beam.
strocker crank (489) good forged pistons (srp) and dart pro 1 heads and a nice hdy roller cam.. ( went solid roller) single plane intake. and a 850 d/p 500rwhp is alot, what you doing to the truck to make it hook.. |
#13 | |
Re: New to BBC
![]() Join Date: Mar 2010
Re: New to BBC
My 496 made more horsepower with brodix 2xtra cnc'd, over the pro 1's. My last bbc I built had cfe bmf cnc'd 385's, 582 c.i made 1115 hp single carb, no power adder. I really think the cfe heads are hard to beat for bbc horsepower.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
#15 | |
Re: New to BBC
#16 |
Re: New to BBC
Where did u get them from
#17 |
Re: New to BBC
$1100 bare ?? I paid $1800 for the brodix 2xtra cnc,d complete, ready to bolt on, Not having to spend $$ for port work is worth quite a bit.
#18 | |
Re: New to BBC
#19 |
My Carbon Footprint
Re: New to BBC
For roughly 550 at the crank, gunna need heads as stated above. Get ya some AFR's....especially if you are going to stroke it. Challenge is going to be either hitting the HP target or the budget. Might be hard to do both.
#20 |
My Carbon Footprint
Re: New to BBC
Carl Foltz....BMF is their "budget" line of heads and they will run you over $3,000 for the pair. Overkill for what you are trying to build and attain.
http://www.cferacing.com/ |
#21 |
My Carbon Footprint
Re: New to BBC
lol....1100 a PAIR not BARE!!
#22 |
Re: New to BBC
wow thats a great price and where did u get them from
#23 |
Re: New to BBC
Good luck on that..
#24 |
Re: New to BBC
You do not need Alum heads AFR/DART/Brodix to make 500-600-700 HP at the crank. I have seen plenty 700 hp 496 with worked over stock Iron heads. Just look at the link i posted earlier. My Iron heads have been used on 680 hp BBC with no work done to them and pump gas. Check out some builds by David Vizard.
#25 |
Re: New to BBC
so who makes a good set of cast iron heads
