10-18-2010, 01:54 AM | #1 |
RAT1968 '68 Cab/'71 Parts
Fuel Lines 68 cab to a 71 chassis
Got the motor in the frame today. A couple of notches for the headers. Some questions arose over the fuel tank from the '71 that I'll be using in the '68 cab that has '71 "Everything Else"
I believe the '71 has the EEC fuel tank. It had the vent tube running up the back space behind the passenger in the cab, which I removed and kept, the canister next to the battery box in the engine bay, which I jettisoned, and a mess of fuel lines running from around the fuel pump to the back. One , in particular, seems strange. It's *outside* the front frame rail and curves up looking to accept a rubber hose (to the cannister?). I think I can figure that there is a feed from the tank (goes back thru the cab floor?), a "return", and a "vent". Is it ba good guess that all three of these hoses go back to the fuel tank and up thru the floor of the cab? The '71 cab (gone to the rust collector/squisher), had two holes in the cab floor, and the '68 has only one. So, what do I actually need? All three? Which is which? I looked on the explosion on LMC and I can't be sure. I'd really like to just use the supply line and whatever else is ABSOLUTELY necessary. Whatever that would be. Thanks. Here's the sparks flying today. The gas is turned off (moved outside) and our eyes and ears are covered.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 10-18-2010 at 01:55 AM. |
10-18-2010, 02:53 AM | #2 |
Has more rust than truck...
Re: Fuel Lines 68 cab to a 71 chassis
Too dark right now to go look for sure, but if you look at the charcoal canister the ports are marked. One line goes to the tank, one to the PCV and another to a vac port on the carb. Hope this helps.
10-18-2010, 08:11 PM | #3 |
Cruzin
my 71 has one line to pump and the other line is just a vent under the cab now
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
10-19-2010, 05:31 PM | #4 | |
Ray |
10-20-2010, 09:09 PM | #5 |
I'm doing the same exact thing, and my current plan is to use a '68 sender (or EEC sender with the vent outlet capped) and get a vented gas cap for my '72 tank. I have yet to hear form anyone that that would be a good way to go and I haven't located a vented cap that will fit.
1968 LWB C20 / AC / Wood Bed |
