Got my 1953 chev last week. It needs alot of cosmetic work but its in pretty good mechanical shape. Got all the wiring done in the last 2 days. I have a few Qs. im trying to find 16in rims that will fit the front so let me know what u guys have been using? Also want to throw a 350 chev in it next yr but need to know what would be a good trans to go with it? Also the drivers side floor is all rusted threw and was wondering if i would be better off just to buy the after market floor and weld it in or if i should make my own (im still in high school and the school has all the stuff to do it)? there will be alot more Qs to come. Theres also a short video of it on youtube called 1953 chevy pickup its like a 30 sec clip user name sofa274.
Re: My 1953 chevy 5 window
sorry pics are on the way just really slow loading.
pics
I noticed that your truck has flat bed rails. Now I could be wrong, but was that not a feature changed in 1954 model? Are you sure that the whole truck is 1953?
Honestly you have the sweet beginning of a sweet ride. I am looking forward to keeping an eye on what your going to do with this truck!
1949 GMC Pickup A lack of planning on your part... ...does not constitute and emergency on mine. Last edited by wigadore; 10-18-2010 at 08:19 PM. |
Im not sure this is a 3/4 ton truck and I've seen some that have the flat bed rails. Im the 3rd owner of this truck so it could have been changed along the way but from what i know every thing on this truck is original. Still had the original hub caps and hopefully i can find a 16in rim that i can put them on.
Thought of some more Qs. The passenger door lower hinge is screwed up just wondering if any one else has had a problem with that before i start to tear into it? It needs a new exhaust system and i figure while im doing it i might as well do something good so open for suggestions on that. The guy i bought it from was backing up one day with the door open and caught a light poll and it creased right in front of the door wondering what the best thing to do there is?
It's a 54-55 bed, but the cab is a 53 (notice the 2 piece windshield and grill)
1953 GMC 1/2 ton long bed Original 228 I6 with a Hydramatic Auto Tranny Project Pack Rat - http://67-72chevytrucks.com/vboard/s....php?p=3374649 ![]() |
With 8 lug wheels and a long bed that would be a 3/4 ton right?
If you have the serial number you can determine what it was originally. Last edited by Atomsplitter; 10-19-2010 at 02:48 PM. |
ya ill have to get it pulled off and check it out hopefully thats all it is.
![]() Join Date: Jan 2009
Two of my hinge pins were sheared off like that. One was determined to be permanently stuck in the arm. My 20 ton press and some heat didnt even touch it, so I had to drill it out. Hopefully you get luckier.
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
![]() Join Date: Oct 2007
i think i have a extra pass lower laying around if you need it let me know it's yours.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) Last edited by 54 jimmy; 10-19-2010 at 08:39 PM. |
if originally equiped, then it's a 3/4 ton. half ton's had 6 lugs, but were available in long beds as well. But the 8 lugs is a give away.
Only GMC 1/2 tons were available with the long bed, Chevy was short bed only.
We need more pics of the bed floor to determine how this truck has been modified. That bed won't fit on an earlier frame without raising the floor because of the hump in the frame that the 54-55's didn't have.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler Last edited by BlueJeep; 10-19-2010 at 10:04 PM. |
Ill see if i cant get more pics on tomorrow. I know that it no longer has a wood bed someone just got a sheet of metal and welded it under there.
#15 |
So ive been doing some checking and the 3/4 ton trucks since 51 had that style of bed.
#16 |
The easiest way to know for sure what it originally was, before any changes, is to check the serial mumber as that tells the year and model of truck!
#17 |
Truck looks good. Great start!
#18 |
Hellasick
![]() Join Date: Jul 2006
Nice looking truck. Your floor looks way better than the one in my '52. Mine also has the pass. door crease, but no noticeable hinge problems.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
#19 |
Well I got the hinge fixed. Also got the drivers window fixed but broke the wing window so now i gotta get that fixed. also got the drivers floor cut out and should have it rebuilt and put back in next week. Ill get some more pics on tomorrow!
#20 |
Master Procrastinator
cool build you planning on keeping it a lwb, what are youre major plans
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
#21 |
Right now plans are to get it going down the road. Hopefully next year I will be putting a 350 in it upgrading handling,suspension. Also probably going to upgrade the rear end and trans probably a few other little things like sound etc.
Tags |
1953 chev 235 |
