02-28-2003, 08:11 PM | #1 |
~THE SILVER BULLET~
help! stuck distributor
k i was tryin to set the timing on my truck and a loosened the bolt just fine but i just cant get the distributor to turn. whats the deal?
~1980 c10 chevy scottsdale~ ~2.5/4 drop 305/th350c~ |
02-28-2003, 10:03 PM | #2 |
Are you sure it's loose, and the vacuum advance canister isn't hitting anything?
03-01-2003, 07:33 PM | #3 |
~THE SILVER BULLET~
yes its loose, i could turn the bolt by hand, and the canister is free. anyone??
03-01-2003, 11:36 PM | #4 |
the same happened to me on a 79 f#@d i use to own. that thang was stuck bad, wouldn't turn for nuthin. i at first thought maybe it was hung up in the block or something but since it ran good i figured maybe not. I guess all the gunk that had settled around where it seated on the block had turned to some kind of undiscovered super duper metal adhesive. the distributor was up front so i took off some the acc. brackets and stuff and was barely able to get a small pipe wrench with a piece of pipe on the end of it(i figured it's a f@#d what the hell) and after busting a few guts it finally popped loose. i pulled it out of the block and didn't see anythng that might have been making it stick like that so i set the timing and everything was fine.
03-01-2003, 11:47 PM | #5 |
~THE SILVER BULLET~
well thats not very encouraging...thanks though
03-02-2003, 12:02 AM | #6 |
Insert Witty Text Here
I have heard of people using the friction type oil filter wrench to break them loose. I would be afraid of breaking something, though.
Slonaker |
03-03-2003, 12:18 AM | #7 |
iF IT BRAKES GETTING IT OUT......it needed to be replaced anayway
03-04-2003, 01:19 AM | #8 |
Genuine Chevrolet
Seen it happen in Fords because they are actually sunk into the intake but never in a Chevy. Someone might have used sealer on both sides of the gasket. Try leaving the bolt loose and taking it for a short "low RPM" drive. The heat and vibration might be enough to break it loose.
George 82 Silverado LWB 4x4 350 SM465 NP208 77 Chevrolet Blazer Chalet 400 TH350 NP203 |
03-04-2003, 09:41 PM | #9 |
~THE SILVER BULLET~
thanks 82 silv, i might try that. my auto teacher is kinda wierd though so he might not let me in class...if not ill do it later
and good point solidaxel...may be time for an msd billet distributor, and an msd 6a hei kit
03-06-2003, 01:01 AM | #10 |
Sounds like a justifible excuse too me!!
