10-18-2010, 08:27 PM | #1 |
dazed and confused
clutch pedal removal
i am thikin about removing my clutch pedal. the truck has an auto in it now. how involved is this? do you need anything special when removing the pedal? thanks in advance
members met: redbaron69, billsbowtie,nc67 |
10-18-2010, 08:49 PM | #2 |
Cruzin
Re: clutch pedal removal
it's been a while but i did mine rather easy just slid out if i remember correctly
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
10-18-2010, 09:11 PM | #3 |
Yea, just remove the pinch bolt , from the lever on the RH end, check that the return spring is off the LH side on top. The peddle should slide right out(just watch for wires in the way). The brake peddle will stay in place. crazy AL
http://community.webshots.com/user/hotrodhorn |
10-18-2010, 10:16 PM | #4 |
longhorn is correct. you can do it bigguy.....
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
08-06-2012, 12:16 AM | #5 |
Ok guys...you make it sound so easy, and it should be, but the top of my pedal hits a curve in the firewall/dash and there is simply not enough room for that thing to slide out. What is the secret and why cant I get mine out???
08-06-2012, 02:06 PM | #6 |
There are two pedal brakets/spring combos. Either one can be taken out whole and the clutch removed on the bench. The lighter duty one can be done in the cab, but, if you have the heavy one, you simply have to take the assembly out whole and take a GREAT DEAL of care removing the spring. If it flips while you are holding the pedal arm, you will lose a finger.
Fortunately, they were able to sew mine back on and I regained most of the use.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
08-06-2012, 08:05 PM | #7 |
I was alittle less ambitious and cut the clutch pedal off a few inches up and slide the rest out since I could turn it further to clear the firewall. now que the '67-72 c10 clutch pedals being worth their weight in gold' trend... lol
08-06-2012, 10:50 PM | #8 |
thanks guys...it would figure I had the larger one. Not sure how to proceed now. I already have the spring and such off...do I take the time to pull the whole assembly out and sell the clutch pedal, or just hack off part of it and get the dang thing out so I can continue on my build....hmmmmmmm. I'm leanin towards hacking....
08-09-2012, 01:09 AM | #9 |
ok, just had one of those "duh" moments...I looked again at how to take out my clutch pedal and all I had to do was rotate the pedal all the way toward the steering wheel and it was able to then slide out. Its all good now!
