Old 10-20-2010, 02:05 AM   #1
extremesounds13
Can a dually be converted to a SRW
I am looking for a 73-87 4x4 crew cab long bed for a 67 crew cab project I am going to start, the only problem is all the 4x4's I keep finding are dually's. Can I convert one to a single rear wheel fairly easily or should I just keep looking?
extremesounds13 is offline   Reply With Quote
Old 10-20-2010, 02:59 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Can a dually be converted to a SRW
Easy to do. Remove the fenders and swap the axel.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-20-2010, 08:08 AM   #3
BigBlocksRule
Easier. Swap the bed and the axle. When you pull dually fenders off, you'll leave a big, unfinished fender opening.
BigBlocksRule is offline   Reply With Quote
Old 10-20-2010, 11:16 AM   #4
walkerb
walkerb's Avatar
^ way easier
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 10-20-2010, 12:00 PM   #5
extremesounds13
So what axle will be in it with the dually and what should I use for the single rear wheel axle, probably a 14 bolt full floater? Are the dually axles a lot narrower than a regular axle?
Old 10-20-2010, 12:41 PM   #6
BigBlocksRule
Dually axles are about 3" narrower than a standard. Find a SRW axle and bolt it in. My bet is that if your dually bed is in decent shape, you can sell it and the axle to someone looking to do the opposite!
Old 10-20-2010, 01:34 PM   #7
Prerunner1982
Prerunner1982's Avatar
I think the dually axles are wider than a single wheel axle. This is why mounting HMMWV wheels to the dually axle brings the tires back into about the same as a SRW axle. The Cab and Chassis dually rear axles are narrower, but the regular dually axles are wider.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 10-20-2010, 01:50 PM   #8
BigBlocksRule
You're right, I had a brain fart. C&C are the narrowest, SRW a bit wider, then dually.
