10-20-2010, 06:19 PM | #1 |
steering problem!!!!
i noticed when i was driving that my steering wheel had alot of free play... when its parked, instead of it being stiff or not moving, it still moves... i dont have much knowledge on steering but if theres anybody out there that does..any tip helps.... thanks
10-20-2010, 06:23 PM | #2 |
Re: steering problem!!!!
Check your steering gear box for play, Also check your tie rods and pitman arm.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
10-20-2010, 07:28 PM | #3 |
Active Member
Check the gearbox adjustment as gearys mentioned. There's an adjsutment you can make there but don't overdo that adjustment. They rarely become maladjusted on their own. If it's real loose, then there is probably worm gear wear and may need to be replaced.
If the play is not in the gearbox, then I would take it in to a front end place and have them check the tie rod ends and ball joints. They have a special tool they use to see how worn they are. That's usually where most of the steering wear will be on these old trucks. |
10-21-2010, 06:44 PM | #4 | |
its not the pitman arm or tie rods..... how can i adjust the gear box? |
10-21-2010, 09:59 PM | #5 |
If its the steering box...time to rebuild or replace. I think.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
10-22-2010, 11:16 AM | #6 | |
Active Member
http://www.chevytrucks.org/tech/steering_box_adjust.htm forgot to add: As cdowns mentioned acquire a manual because the adjustments can be critical if not done properly. Just remember that this and the brake system is probably the most important thing to make sure is working right. Last edited by 68gmsee; 10-22-2010 at 11:23 AM. |
10-20-2010, 08:50 PM | #7 |
vw guy & now c-10 guy
yeah, look at the pitman arm- I had replaced nearly every part in my front end besides that piece when I did the drop and then found I had excessive play in the pitman arm link- I could wiggle the steering shaft and watch the arm move back and forth...
10-20-2010, 11:24 PM | #8 |
Probably steering box... pretty common
10-22-2010, 09:49 AM | #9 |
Don't forget to check the shaft coupler joint. It could be worn out.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
10-22-2010, 09:58 AM | #10 |
improperly adjusting that screw can cause catastropic failure at the worst possible time// read about it in factory service manual for proper way to do it for safety
