10-22-2010, 05:45 PM | #1 |
front and rear "axle"
My first post...tadaa Who makes the BEST ifs-frontclip for a 1949 3100 pu. Thats going to be a daily driver, and what rear axle to use ? I am going to ride a tpi 350 and a 700 transm. The swede
10-22-2010, 08:22 PM | #2 |
Re: front and rear "axle"
Nobody answered so far? There are many IFS, I just had one put on my 55 chevy from Scott's Hot Rods and I am impressed with it. Although I have not seen them all. Several folks seem to make good ones. Also you can get a good deal from Scotts by being a forum member...Do a search and talk to Justin. Also do a search on this forum for IFS and you will get good info.
10-22-2010, 08:27 PM | #3 |
10-23-2010, 07:03 PM | #4 | |
10-23-2010, 01:21 AM | #5 |
Hi Swede
Welcome to the forum from Canada! I vote for the Scott's IFS as well, I think it's the best I've seen. I don't like mustang 2 kits on these trucks but some people do. For the rear axle I prefer early 70's Nova up to 1979 or 70-81 Camaro/Firebird which are a little bit wider. These are 8.5" ring gear which is quite strong and quite common (cheap) Can you post some pictures of your truck? Bob
1962 Chevy blue SBFS 1957 Chevy yellow SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ Last edited by bobinbc; 10-23-2010 at 02:27 AM. Reason: year |
10-23-2010, 07:30 PM | #6 | |
10-23-2010, 08:09 PM | #7 |
Nova 60.25 total width , 70-81 Camaro 62.50 after 1972 up to 81 all are 8.5" Nova & Camaro
Here's a link to some rearend sizes http://www.carnut.com/specs/rear.html
1962 Chevy blue SBFS 1957 Chevy yellow SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ Last edited by bobinbc; 10-24-2010 at 01:57 AM. |
12-27-2010, 11:00 AM | #8 |
Now i found a late-60s GM B-body (el-camino ) axle with a 3.36 gear ratio and a lim.slip diff ..I think that will be just fine after a little work !!!
12-27-2010, 11:09 AM | #9 |
Here it is !! My -49 on its last journey as a beaten stocker !
12-27-2010, 11:32 PM | #10 | |
Posted via Mobile Device |
12-28-2010, 12:46 AM | #11 |
I'm using a No Limit wide ride IFS and a rearend out of a Explorer. I was impressed with the IFS I got, and I also don't like Mustang II based units which mine is not. No Limit are also forum vendors.
1958 Fleetside shortbox 1965 Malibu SS 1970 Camaro RS 1972 Malibu wagon |
12-28-2010, 03:38 PM | #12 |
Tchia65, the No Limit stuff looks really good as does the Scotts (and some others). Just a point though, the IFS I have only shares the spindles from a MS II. The rest is engineered via Scotts, it is not normall MS II track width. I noticed that the No Limit stuff uses a 2nd Gen Camaro spindle. Both use a later model Cougar rack. So really this is one's preference regarding which comany(s) to use. Should work out good either way.
12-29-2010, 12:47 AM | #13 | |
12-29-2010, 09:29 PM | #14 |
I recently purchased a Flat out engineering corvette kit for both the front and rear of my 52. I like that its all chevy (again personal choice).
01-06-2011, 05:07 PM | #15 |
I really like the idea of driving with all GM parts, I am probably only going with the frontend . What year do you use ??? Have you started working on the modifications ?? Please keep me updated ( i have allready started to look after a frontend )
01-06-2011, 05:52 PM | #16 |
Scotts is just as much MMII as any of the other companies are.
I had/am having a bad experience with my scotts and can't wait for the day I rebuild all the control arms. I've had a great experience with Heidts though on another build. for a rear end I think a generic 10 bolt with 3.73 gears would be nice. Last edited by cajundragger; 01-06-2011 at 06:34 PM. |
01-06-2011, 06:33 PM | #17 | |
You suggested to us that you had replace them with energy suspension bushings which are the same bushings we use. You claim how well your truck handles but on the other hand you bad mouth us any chance you get. Which is it? Since I have joined Scotts I have seen Justin rectify any problem that has come about. I also have aquired a few large accounts that where once accounts of other front end manufactures and praise us on our quality and craftsmanship compared to others and have told us there horror stories with the other companies... So with pro builders praising us and my own personal appriciation for the product I find it funny that you constantly bad mouth not only us, but you also like to get in to pissing matches with other credible vendors on the site... If you are so unhappy with that front end cut it off send it in and We will buy you that heidts front end that you want so badly... |
01-06-2011, 07:01 PM | #18 |
Wow..... i love when someone stands behind their product... Kudos
01-06-2011, 06:59 PM | #19 |
The OP asked for opinion.
I gave opinion based on what I have experience with. I've heard NOLIMIT and Fatman is great, have I used any of their products? no, so I dont comment on their product. I've used your front end, and hedits. So I compare your front end to heidts and I choose heidts...which is my opnion, again based on the experince I have. Im not going to create a pissing match with you like your asking me to because I'd really love to counter your post, but I'll let you have this one. I will make a whole new thread if you'd like about my whole scotts experience and what mod's I've done to my front end to make it work like it does. But I'd probably get banned again in the process. |
01-06-2011, 07:11 PM | #20 |
01-06-2011, 08:54 PM | #21 | ||
I had a problem with scotts, many didnt. I have had no problems with hedits, Scott's says they've been known for problems. so in the end take all the advise you can muster, good and bad, and make an informed decision. |
01-07-2011, 08:25 AM | #22 | |
Catchy title goes here..
This is the last I expect to see of you following them around crapping in their threads. Thanks! |
01-07-2011, 09:04 AM | #23 |
Now that MY FIRST thread isnt cloosed longer...http://67-72chevytrucks.com/vboard/s...=439252:truck:
01-07-2011, 10:54 AM | #24 |
how did I troll the vendor? I posted my post and was done. Then the vendor came back at me...I didnt follow anyone. I believe it was the other way around.
01-06-2011, 07:08 PM | #25 |
Certified Car Nut
This is getting ridiculous. Is this what this site has come to? Bashing vendors and products that people are using on their cars. If there are hundreds of Scott's IFS out there and one person had a bad experience that does not make the product bad.lol That just makes that one persons experience bad and all Scott's can do is try to make it right and he says he has. There are a lot of IFS manufacturers out there that make really nice products. Scott's, No Limit, Art Morrison, Jim Meyer, Heidts, and TCI to name a few. I have not install a Scott's unit but I know people who have them and love them and would not use anything else, but I know people who say that about some of the other companies I mentioned. So can we move on and give people the info they need to make an informed decision without the bashing. I thought that was what this site was about.
