10-22-2010, 07:41 PM | #1 |
Short bed to Blazer?
Here's the question. Will a Blazer body fit onto a short bed 2WD frame?
Reason I'm asking is I may have the oportunity to pick up a 73 short bed with a real poor body. I know there are numerous Blazers tht are parked due to smog problems here in California. Maybe I can put the two together and have a 2wd Blazer with a smog free chassis? |
10-22-2010, 07:59 PM | #2 |
Re: Short bed to Blazer?
It would be titled whatever year the body was. It carries the vin.
Posted via Mobile Device |
10-22-2010, 08:11 PM | #3 |
10-22-2010, 09:50 PM | #4 |
maybe you could explain this statement in a little more detail
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
10-23-2010, 12:14 AM | #5 | |
A lot of things may be different in CA. A vehicle is always registered according to the vin on the body.
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
10-25-2010, 01:16 AM | #6 |
my truck started out as an 85, cracked frame, ment a frame replacement with a 75 frame and title, using the 85 body and bed, dmv titled it as a 75 because of the frame numbers
10-22-2010, 08:30 PM | #7 | |
Not without cutting the frame at the minimum. Frank
Born and proudly residing in a Red State ! |
10-25-2010, 07:42 AM | #8 |
wow! i've never heard of that... did you have to swap vin tags on the cab then?
10-25-2010, 10:59 AM | #9 | |
Please let us know
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project) It's your ride build it the way you want !!!!!!!!!! |
10-25-2010, 11:09 AM | #10 |
yes, the 75 vin tag is in the door, and the 85 vin is gone, the PO did the swap, he's a friend of mine, I know it went to the dmv for verification, and they mached the vin to the frame. and the frame numbers were the key to it being titled as a 75.
