Old 10-22-2010, 08:01 PM   #1
Uwe Blab
Uwe Blab's Avatar
O/D relay wiring question
I am, what is hopefully, in the final stages of installing a 3-speed transmission with electronic overdrive. The transmission is out of a '55 truck, but I'm putting it in a 1970 C/10. The question I have is regarding the relay. I've acquired a 3-post version out of a F**d, but I'm not sure if it may be what's keeping the transmission from kicking into o/d. It has a connection for the transmission solenoid, kickdown switch, and the battery, but only when the ignition is turned on. I had a 4-post relay, which had an additional connection to the battery permanently, but it was a faulty relay.
Bottom line, should the 3-post relay be sufficient to run the transmission?
Thanks in advance for your help.
Adam
Uwe Blab is offline   Reply With Quote
