Old 10-23-2010, 11:20 AM   #1
vanceman
Pro Street E - Brake Cable???????
To all of you pro streeters, what are you using for an E Brake cables? I am in the process of redoing my rear drum brakes and I am wondering what everyone is using for that first section of E- brake cable.
vanceman is offline   Reply With Quote
Old 10-24-2010, 09:02 AM   #2
vanceman
Re: Pro Street E - Brake Cable???????
Ttt
Old 10-24-2010, 08:51 PM   #3
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
I am still using the stock units - I had to fab an eye bolt to the trailing to pull the away from the wheels or they would rub
If you are going to disc simply buy the units designed for the rear that accomadate ebrakes
Your other option would be to go to a disc on the back of the tranny or the front of the rear end. You would have a mechancal caliper to lock against the disc to act as your parking brake
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 10-24-2010, 09:13 PM   #4
vanceman
Thanks, You got any pics?
Old 10-24-2010, 11:31 PM   #5
tonypaul
tonypaul's Avatar
Im sorry Im kinda out of the loop on alot of things - what is "pro streeters"?
tonypaul is offline   Reply With Quote
Old 10-25-2010, 12:04 AM   #6
69heavychevy
69heavychevy's Avatar
fast car/truck with big balls and some thick meat!!
69heavychevy is offline   Reply With Quote
Old 10-25-2010, 11:30 AM   #7
Zeke's Garage
Zeke's Garage's Avatar
Well that cleared it up nicely....
Zeke's Garage is offline   Reply With Quote
