10-24-2010, 08:12 PM | #1 |
Anyway to lay factory crossmember and not arms?
Anyway I lay my factory crossmember and not the arms? If so what arms will work? I currently have 1971 suspension, 3" drop spindles, upper plates, 2600 bags, 27" tall tire.
10-24-2010, 10:15 PM | #2 |
Happy to be here
Re: Anyway to lay factory crossmember and not arms?
If you section the crossmember.....
10-25-2010, 12:00 AM | #3 |
SSN 706
I got some pics on page 10 of my build.
10-25-2010, 11:36 AM | #4 |
needs more $$$
On my bro's C10, he has lcas that mount in a recessed area of the crossmember that was cut. They are from Turner Enterprises, which isn't around any longer. The xmbr is also sectioned 1.5" in the pic. I don't know if any other lcas mount this way.
1970 2wd Blazer Last edited by tubbedII; 10-25-2010 at 11:37 AM. |
11-01-2010, 10:25 AM | #5 |
Does this set up work good for you? I had a buddy with the same turner set up and it kept the camber positive all the time.
11-01-2010, 02:11 PM | #6 | |
needs more $$$
Once get gets back into the project, he's going to dump it all and get a drop member. There's a modified MII rack on it now for steering, but he doesn't trust it, and figures with the lack of fab skills, it's best to be safe.
1970 2wd Blazer |
10-28-2010, 02:24 PM | #7 |
I dont see how a section c-member will allow it to not lay arms unless you sectioned it so much so that the frame would lay before. In which you'd be better off z'ing the frame because a c-member drop that big will cause alot of binding issues.
10-28-2010, 02:48 PM | #8 |
SSN 706
Mine lays frame. 1 1/2 taken out of the crossmember, dropped spindles, orginal arms modified w/bags.
