Old 10-30-2010, 12:53 PM   #1
csa daddy
csa daddy's Avatar
info for putting a rac an pinnion in a sqare body
What year rac will work an does it have to come from mustang or can it come from a lincon or something
csa daddy is offline   Reply With Quote
Old 10-30-2010, 05:42 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: info for putting a rac an pinnion in a sqare body
Any of those can be "made" to work, but you will have to do just that.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-31-2010, 10:07 AM   #3
csa daddy
csa daddy's Avatar
Well I understand that I have to make it work but I want to make sure I get one that is up to the task. Best to get one from a v8 I guess
Old 10-31-2010, 10:09 AM   #4
csa daddy
csa daddy's Avatar
An thanks n2trucks I guess I will go by the pick an save a get one
Old 10-31-2010, 10:16 AM   #5
mfl1
mfl1's Avatar
i used one out of a late 80s fox body mustang v8 and made it work. also bought the heim and adjuster from ***************** on a 70 sub but same basic suspension
mfl1 is offline   Reply With Quote
Old 10-31-2010, 12:08 PM   #6
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
From www.jimmeyerracing.com
BOLT-IN FRONT STEER IFS
'60-87 GM/GMC Pickups -- A total bolt-in package
Using stock-existing factory holes, this easy-to-install, bolt-in or weld-in IFS kit featuring ‘78-88 front-steer Impala spindles, 12-inch diameter (Impala) rotors, calipers, and balljoints will give you a 5-on-5-inch diameter bolt pattern. The stock crossmember will unbolt and is replaced with a new 2 x 4 x .188-inch wall bolt-in crossmember that holds a ’83-87 T-Bird power rack-and-pinion steering unit. Either a stock, power GM gear-box pump or GM rack pump is compatible to operate the rack. C-channel frame stiffeners, that bolt inside the frame, are also included in the kit. Modifications to the bottom of the steering column will be necessary to connect to the rack spline, or replace it with an ididit column.
The stock 64 1/2-inch front track width is narrowed to 62 1/2-inches with the new IFS kit. The kit features D.O.M. tubing upper-and-lower A-arms (1 1/4-inch dia. X .156-inch wall lower arms and a 1-inch dia. X .156-inch wall upper arm). The aluminum, adjustable coilover shocks with powder coated springs are attached to a three-position upper mount and a two-position lower mount that offers you about 4-inches of movement for the stance you like best!
Dropped spindles, custom track widths, 1-inch diameter sway bar, steering linkage kit and column are just part of the options available.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 10-31-2010, 12:17 PM   #7
rustyescott
rustyescott's Avatar
Mfl1 do you have more pictures of you rack set up
rustyescott is offline   Reply With Quote
Old 10-31-2010, 12:52 PM   #8
mfl1
mfl1's Avatar
here you go rustyescott
Old 10-31-2010, 09:19 PM   #9
csa daddy
csa daddy's Avatar
Mfl1 did u raise your motor or is still in the same location just diff mounts but thanks this is some good info for this little project
Old 10-31-2010, 11:46 PM   #10
mfl1
mfl1's Avatar
its raised 3" because we raised the crossmember for body drop, otherwise it woundn't need to be.
Old 11-01-2010, 12:55 PM   #11
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
does it take a beaffyer rack for a C30? i got one laying around from a old Mercedes i have thought about converting to rack and pinnion because of the better steering
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 11-01-2010, 08:27 PM   #12
csa daddy
csa daddy's Avatar
I guess u can use about any rack. Just some moding to make it work. mfL1 my crossmember is chopped 1 3/4" an z'd 3 inches but I don't think I have to change my original motor mounts. I also think I'm going to move the front crossmember forward an inch an use a set of sucide doors upper a arm mounts like dv8 did on his truck. That way my wheels will set a full inch narrower than stock
