10-30-2010, 10:28 PM | #1 |
Something seems wrong...
I got a 69 chevy c10 and I use it to drive 25 miles one way to college everyday. I installed a tach that I bought from harbor freight for $20. When I drive I go about 63 mph because the tach reads just under 5000 rpms! The engine is pretty noisy going that fast. I'm just wondering if there is anything wrong with my truck or if it's just a cheap tach. I couldn't imagine a tach being that far off. It seems like everyone else that has something around my set up revs around 2200-2500 rpms... The truck has got a 307 muncie 4 speed and 3:08 gears in the rear end. I know it has 3:08's because I took the cover off and counted the ring and pinion myself and divided. Any ideas what's going on?
10-30-2010, 10:35 PM | #2 |
Cruzin
Re: Something seems wrong...
does the tach have the switch on it were you switch for 4 cyl. 6cyl or 8cyl? and its in the wrong position? just a thought.............
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
10-30-2010, 10:37 PM | #3 |
On the back of the tach I bought, there were settings for 4 cylinder, 6 cylinder and 8 cylinder. See if the one you bought has one, it should be on the back. The other problem may be it came from Harbor Freight. Thats the best I can do, if this doesn't solve it I hope someone else can! Good luck!
EDIT: Hubscrub beat me too it! Haha.
---| 1967 GMC Stepside |-- 250 L6 .030 over ---| 1985 Porsche 944/1 |--- Build Thread: '67 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=378640 Last edited by LandonL; 10-30-2010 at 10:37 PM. |
10-30-2010, 10:44 PM | #4 |
haha ya you guys are both right. I actually just checked before I reposted and the switch was and is on the v8 position. I thought it was just because it's harbor freight S#@T, but I just can't imagine a product being THAT far off. The engine is VERY noisy going that fast too.
10-30-2010, 10:47 PM | #5 |
I bought it awhile ago...like last spring probably. I'm actually bringing my truck down to brookings to visit my friend at college!
10-30-2010, 11:25 PM | #6 |
The Older Generation
I have one of those in my Green '67 and even though the needle is not real steady it seems to be pretty accurate. I can't see how you could be turning that many rpm with the setup you have. Yes, the engine might be noisy at 63 mph but I can't believe 5000 rpm worth.... LockDoc
10-30-2010, 10:40 PM | #7 |
Think your tach is a piece or the setting is wrong on the back.Assuming and 29" tire your should be running just over 2200 rpm.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14, |
10-30-2010, 10:41 PM | #8 |
Just because something is new, doesn't mean it works correctly. Check out what the first two people suggest, if that doesn't work return it for a new one.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
10-30-2010, 11:59 PM | #9 |
Grandpa in the rustmobile...
dang does it sound like 5k lol!! 5k i couldnt drive @ that much rpm for long!!! LOL
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-31-2010, 07:10 AM | #10 |
Since nobody else asked, what kind of ignition setup do you have? Some tachs made for points do not work right with HEI, and sometimes the reverse is true also.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
10-31-2010, 09:42 PM | #11 |
I guess I'm not really sure what ignition system I have...I haven't changed anything on it. So I'm assuming it's stock. Whatever type of system that is. What's the difference in types?
10-31-2010, 10:30 PM | #12 | |
HEI and other types of electronic ignition replace the points with a magnetic sensor. The problem is that the two types of systems generate a signal that the tach "sees" differently. Most modern tachs will work on either type of system without a problem, but a few of them won't. Ray
10-31-2010, 10:35 PM | #13 | |
10-31-2010, 10:23 PM | #14 |
if its unchanged from the factory its the old points style
newer is HEI
11-01-2010, 01:41 PM | #15 |
I know you said you have a C10, but is the truck 4wd? That's about where mine would shift if I had transfer case in 4Lo.
Dave 1971 Chevy K10 1972 Chevy C10 |
11-01-2010, 05:41 PM | #16 |
Old Duffer
I probably missed it somewhere.....is this an eight or six cylinder engine?
Never mind, I see it.....307. Sorry
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." Last edited by slomotion; 11-01-2010 at 05:56 PM. Reason: numb |
11-01-2010, 06:36 PM | #17 |
theirs no exhaust leak is their?
1972 gmc c25 292/sm465 dana 60 w/5.13s 1973 vw super beetle 1600cc/4spd(baja bug) 1974 chevy c60 351v6/np-540+2 speed eaton rear 2005 chevy cobalt 2.2l |
11-01-2010, 06:37 PM | #18 |
20' Daredevil (Ret)
Have you verified your actual speed with a GPS or by time between mile posts? Maybe you're running along at 95 or so, which would explain the truck being so noisy.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
11-02-2010, 06:33 PM | #19 | |
My exhaust shouldn't have a leak... The only other thing that I could think that could be effecting this is maybe my lifters. They sound awful, or at least I think that's what is causing a really bad sound. Everytime I accelerate it sounds thug-thug-thug-thug or it seems like there is a gap of air being released or something. I don't know how to really explain this...Has anyone else ever had this problem? Maybe this problem wouldn't have anything to do with my tach, the thing just could be a piece of junk as I only spent $20 dollars on it. From the beginning I was planning on buying the full instrument cluster that comes with the battery gauge and oil pressure and even the built in tachometer. Does anyone know if these built in tachs are pretty accurate?? Or would it be better to buy a really nice tach and put it on my steering column? |
11-02-2010, 07:54 PM | #20 |
20' Daredevil (Ret)
Awfully hard to diagnose a noise over the internet, but you seem to be describing an exhaust leak, possibly at the manifolds. If so, it should be slightly louder on cold startup. If you're quick, you can carefully feel all around each manifold for escaping air before it gets too hot. Don't touch them, just feel for little blasts of air.
11-02-2010, 10:38 PM | #21 | |
I guess I never really thought that noise could be an exhaust leak... That would be a realieve if it turned out the noise was from the exhaust. Then I know I don't have to go into the engine very deeply. I'll check for one tom. hopefully I can get it pin-pointed. If not I'm coming to you and you can fix it! |
