heat
Im wondering what some of you guys do for heat during those cold winter months in your garage, I should have said 220v
Re: heat
I used to have a wood stove in the garage but when I reroofed the house and garage I pulled it out......bad mistake..boy do I regret it.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
SSN 706
Re: heat
80,000 btu natural gas. My last one was a Hot Dawg it was better.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 11-01-2010 at 09:33 AM. |
2nd part question for heat
okay now its freaky cold here in Indiana and I still have some painting to do. what do you guys do to keep painting here in the midwest other then having a nice heated shop. Im in a 2 car garage Thanks in advance for any advice
Re: heat
Halogen high intensity work lights at harbour freight, put out a lot of heat.
Re: heat
If your painting, keep in mind its not just the air temp; its the thermal mass of what your painting. If you have just started warming the garage, a heater might make the room feel a nice 72 degrees but your project may still be much colder. Use a heater that puts out good infrared radiant heat.
292 + TKO500 |
Re: heat
great ideas on getting some heat in the garage, I do have a heat lamp that use on the surface of the area Im painting. I did find a heater at manards that is a 220v that I can hang on the wall that heats up to 400 sq ft My worries are if I paint a little should I be worried about fire or blowing up my house?
Resistance is Futile
Re: heat
The paint fumes would have to reach a certain concentration to blow up. I would assume you would be venting the area while painting. Tough call on that one.
I have a very small 220v heater that rattles and makes noise but will warm up a small area if I need to do something outside during winter.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
