Old 11-01-2010, 09:58 AM   #1
remist17
remist17's Avatar
TH400 Kickdown Switch - HELP
I am doing a V6 to V8 swap. The truck is a 87 Chevy. Origianally had a TBI and the 400 in it. Getting a new trans and running a carb.
Need help on installing the knock down switch. Were do you put it? On the pedal or the carb. The carb switch needs a 350 or 700 bracket. How does the switch mount to the bracket?
ANy help or photos would be great!
2013 Chevy Silverado, Z71, 5.3L, 4 door
2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40
Support the Troops.
remist17 is offline   Reply With Quote
Old 11-01-2010, 10:02 AM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: TH400 Kickdown Switch - HELP
I believe the kick down switch mounts down by the pedal.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 11-01-2010, 10:33 AM   #3
remist17
remist17's Avatar
Anyone have photos of the switch mounted near the carb. Please keep in mind I am running a air gab edelbrac intake
Support the Troops.
Old 11-01-2010, 11:30 AM   #4
baclay9
Kick down on TH400 is electrically operated by a switch your go pedal hits. If you can't find one I believe Lokar makes an aftermarket one that works a little differently.
baclay9 is offline   Reply With Quote
Old 11-01-2010, 12:28 PM   #5
remist17
remist17's Avatar
Yea I know about the switch but were is it located. I figure the old truck had a 400 it should still be there. Could it be on the old motor?
I never had a 400 before so sorry for the dumb question but were should the switch be located so I can see if it is still there?
Support the Troops.
Old 11-01-2010, 12:53 PM   #6
baclay9
Under the dash. Your actual gas pedal contacts it. The switch is brown and is mounted on a bracket It should have a white and orange wire coming off of it if I remember correctlly.
Old 11-01-2010, 01:56 PM   #7
babyJay
Arrived on a Pale Horse
babyJay's Avatar
TH 350 is an actual kickdown cable between the trans and the carb linkage. TH400 does it electrically, and had no connection to the engine, so you're looking in the wrong area. Like the others said, it's a switch on the gas pedal bracket similar to the ones on the brake pedal that operate your brake lights and cruise control. The wire goes to a plug on the side of the trans.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 11-01-2010, 02:30 PM   #8
remist17
remist17's Avatar
I was informed that this year since it has a computer handles the switch duties and there is no switch. Instead of a switch the computer reads the throttle position sensor and then sends the power to the trans to shift.
I am getting so confused
Support the Troops.
