Hello. This is my first thread post. I bought two 1972 Blazers with the thought of making one awesome Blazer from the two. One has 3/4 ton axels, the rear is a 14 bolt and the other one is a 1/2 ton axel. I do not know which way to go with the axels. Should I make it a 3/4 ton truck or a 1/2 ton truck? My plans are to make it a street driver. No off-roading. I heard the 3/4 has a rougher ride, but I am not sure. Any advice would be helpful. I am so excited to begin my restoration. Thanks.
Re: 3/4 ton axles or 1/2 ton axles on 72 Blazer
Tire size is your guide....
36" is about the limit for 1/2 tons, anything larger and you'll want the beefier axles. -G
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well™" Build |
the 3/4 ton front is not any stonger axle/carrier wise, they are the same thing the only thing you gain is 8 lugs verse 6
the 14 bolt is a HELL of alot stronger than the 12/10 bolt on a half ton if you are not planning on going off road i would run the 6 lug stuff. if you are going to run 15 inch wheels they are ALOT easier to find and tires are easier to find for 15in wheels. on the ride , it doesnt matter what axle you have the ride is in the suspension. |
Stick with the 1/2 ton stuff.
Why is that? I only recommended him to stay 1/2 ton because of how he described the build. I myself am going with 3/4 ton axles to gain larger brakes and stronger components. Why do you wish you stayed 1/2 ton?
Great advice. I want to put 20inch rims with some thick tires, nothing too 4x4 looking. The concept of the Blazer is to have a 4x4 Blazer with the look of a dropped 2x2 Blazer. I hope that makes sense. Thanks for the response.
Well it looks like I am going to stick with the 1/2 ton stuff and maybe build a 3/4 ton pick up truck with the other frame and axles. I think I can make a cool 4x4 pick up truck. Thanks for all the responses. I am excited to restore my 72 Blazer. God bless.
I am new to the scene. What is a good gear ratio? I know the 3/4 ton gear ratio is 4:10. I do not know what the 1/2 gear ratio is. Thanks everyone.
That's a tough question to answer.
Need to know the tire size you want to run, the transmission you want to run, and what is an acceptable RPM (in your opinion) for highway speeds, be that 55mph or 75mph or whatever. You said you want 20" rims and low-pro tires - right? So would the tire height be 24" ( as a guess?) then 4.10 seems too high (numerically) for your application. Most people with 4.10s will be running 33" to even 36/37" tires. Once you know all these answers there are gear ratio calculators that can fine tune the right number for you. I would guess a 3.08 might be right on the money for you. Last edited by SeventyOne; 11-06-2010 at 08:13 PM. |
#11 | |
![]() Quote:
Tags |
1/2, 3/4, axels, blazer |
