11-04-2010, 03:17 PM | #1 |
Sanding the cab.
Good Afternoon to you all!,
The time has finally come to sand down the frame all the way to the metal. The question i have is what Grit sandpaper do i need? what tools would help this process? Thanks in advance for you input! |
11-04-2010, 03:50 PM | #2 |
Re: Sanding the cab.
Wow. That is not a job I would want. I would pass on the sand paper and find a sandblaster. I have used a wire wheel previously.
Are you sanding the cab (thread subject) or the frame (thread body)? Last edited by Alex Hayley; 11-04-2010 at 03:53 PM. |
11-04-2010, 06:32 PM | #3 |
I guess if I proof read what was written i wouldn't feel like an idiot! The Cab
11-04-2010, 06:53 PM | #4 |
Old School
I have found my Dewalt electric DA sander to be indespensible in removing old finish from metal. Just start with 60 or 80 grit and work your way to a finer grit from there. Don't be tempted to use it to smooth out bondo, though.
Leave that work to a long sanding board. A DA sander will cut into the bondo too much and leave the surface wavy. Rollock sanding disks on a die grinder is good for reaching into corners. Have plenty of elbow grease handy.
#1 Project...69 Chevy swb Fleetside (Dad's truck) #2...1983 El Camino SS (Choo Choo Custom) #3...1974 Datsun truck (4.3L V6/4L60E) #4...1951 Cadillac Limo (1975 Caddy running gear) #5...1938 Dodge M38 3/4 ton Military truck #6...1968 Sportster XLCH trail bike 5 GMC & Chevy parts trucks 68 to 72 Last but not least; My 1978 Harley Davidson Electraglide (trusted & reliable companion for the last 30 years) |
11-04-2010, 08:11 PM | #5 |
Old School
That one would work just fine.
#1 Project...69 Chevy swb Fleetside (Dad's truck) #2...1983 El Camino SS (Choo Choo Custom) #3...1974 Datsun truck (4.3L V6/4L60E) #4...1951 Cadillac Limo (1975 Caddy running gear) #5...1938 Dodge M38 3/4 ton Military truck #6...1968 Sportster XLCH trail bike 5 GMC & Chevy parts trucks 68 to 72 Last but not least; My 1978 Harley Davidson Electraglide (trusted & reliable companion for the last 30 years) Last edited by BOZO; 11-04-2010 at 08:17 PM. |
11-04-2010, 03:51 PM | #6 |
double post....
11-04-2010, 06:37 PM | #7 |
No problem. I have made worse mistakes. I don't know anything about sanding/preparing a cab but that is getting close to being the next task on my list so I am interested.
11-04-2010, 07:49 PM | #8 |
Would this http://www.deltaportercable.com/Prod...roductID=15050 be considered a DA Sander?
11-04-2010, 08:25 PM | #9 |
Spanked once
Anything made of this material is good , they have them that work real good with a die grinder ect.
http://www.eastwood.com/poly-x-paint...cup-style.html
The ole 350 budget build. |
11-04-2010, 08:42 PM | #10 |
I always start with Aircraft Stripper. Get the good stuff at Napa instead of the cheap stuff at Autozone. It saves a LOT of elbow work. Be sure to wear long sleeve rubber gloves and also wear eye protection.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
11-05-2010, 12:10 AM | #11 |
If you want to maybe try a couple different things and see what works best for you, you could try and use an angle grinder and put a paint stripping/sanding disk on it. That is what I'm currently using on my cab and fenders and stuff and it works like a charm! Although I don't have the big power tools with air compressors and all that so I'am limited. The disks look like a blue hardened sponge. I've gone through a couple already, but for what tools I have, I believe it's the fastest (that I've found). Good luck!
11-05-2010, 10:34 AM | #12 |
Wow Thanks for all your input, I will try the good aircraft stripper if it helps to cut down on sanding time its worth a try! I will also try that paint stripper/remover disc it looks like it will help too, if all else fails I will sand it!
11-05-2010, 11:19 AM | #13 |
Junior Member
I started out to sand and scrape then found a metal finisher locally. Here are before and after. Makes things a lot easier.
11-06-2010, 03:22 PM | #14 |
Simple? What's simple?
I once did this by hand on an S10 - it was a miserable experience and my hands hurt for weeks!
That said, definitely start out about 60-80 grit on a DA. Another tip is to be careful about the pressure you apply - trying to work too fast / with too much pressure generates a lot of heat and you can warp sheetmetal. As long as you're mindful of the pressure, it won't be a problem
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
11-06-2010, 04:41 PM | #15 |
It depends on how many coats of paint is on the truck, if it is the original paint I would use a DA with 180 and I would never use a grinder it is too easy to gouge the metal and then you have unnecessary body work. If your truck has many coats of paint I would use stripper and then a DA with 220 to the metal. Body work is labor intensive and you can’t take a shortcut that is why body shops charge so much, it is more for the labor.
11-06-2010, 04:49 PM | #16 |
One of the First
Not to Hijack the thread. - Roland, was the cab sand blasted or media (plastic) blasted?
I perfer media blasting on good/non-rusty sheetmetal.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
11-06-2010, 06:54 PM | #17 |
Caustic dip with phosphate coating is thee best...
Metalworks Eugene Oregon does amazing work!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
11-06-2010, 10:59 PM | #18 |
Junior Member
Yep, Hot caustic with phosphate coating.
