Old 11-04-2010, 10:04 PM   #1
509nat
509nat's Avatar
Wood floor to steel floor?
Looking for thread to replace short step side wood floor with steel floor on 1957 chevy truck.
509nat
509nat is offline   Reply With Quote
Old 11-04-2010, 10:51 PM   #2
kaycee
kaycee's Avatar
Re: Wood floor to steel floor?
I did this in my 69,I found a 80 something F@#D truck that had a nice floor in it.then got the measurements from my bed.Seems like it was 55" x 74" took a plasma cutter and cut away.Made the neds a lttle longer so I could grind them smooth and make it look nicer as you will see the 2 ends (tailgate and header)the sides will be covered up by the angle strips.Then I coated it up with some Herculiner.I went to Home Depot and got some carriage bolts and mounted it to the cross sills just like it allways was.Will more than likely do it to the Apache
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 11-12-2010, 10:01 AM   #3
kgmunro
Depending on wether you are hauling or not a sheet of polished diamond plate looks great as a bed floor.
kgmunro is offline   Reply With Quote
Old 11-12-2010, 11:37 AM   #4
355bullet
355bullet's Avatar
i think the 1990 stepside bed floor might fit
355bullet is offline   Reply With Quote
Old 11-22-2010, 01:53 PM   #5
bondobob
bondobob's Avatar
Check out some of my old posts (search "bondobob"). I used steel replacement panels over a 1" by 1" square tube framework on my '57. It's raised in the front to clear a 20 gallon gas tank and the frame steps. Lot's of welding but I didn't want wood. FYI: I'm getting back on the truck project after a 3 year layoff. (Divorce, move, buy house, add to garage)
edit: Can't seem to find any of my old posts. Is this normal?
bondobob is offline   Reply With Quote
Old 11-22-2010, 04:33 PM   #6
Spackle100
Hey Bondobob,
Your thread probably got moved here: http://67-72chevytrucks.com/vboard/f...play.php?f=205
Spackle100 is offline   Reply With Quote
Old 11-22-2010, 07:25 PM   #7
509nat
509nat's Avatar
I appreciate all suggestions and pictures!
509nat
