Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 11-07-2010, 07:44 PM   #1
RIA69
RIA69's Avatar
took the leap. Cut my dash.
ok so this was pretty much one of my first mods to my truck other then a few part installs. so what do you think? did I do a good job at getting it done? I used a dremal tool with a cutting wheel. only took about 15 mins to actually cut it. the rest of the time was getting it to balance right. was a little back heavy to I placed some rubber washers between the ash tray and radio sleeve.
1969 C20 3/4
ΜΟΛΩΝ ΛΑΒΕ
RIA69 is offline   Reply With Quote
Old 11-07-2010, 07:45 PM   #2
AceX
>130dB Moderator
AceX's Avatar
Re: took the leap. Cut my dash.
So proud of you...
Now if only more guys would become men and cut something up lol
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 11-07-2010, 08:01 PM   #3
kalirodding
CLASSIX Truck Club
kalirodding's Avatar
Congratulations, you just ruined your truck.
kalirodding is offline   Reply With Quote
Old 11-07-2010, 08:13 PM   #4
RIA69
RIA69's Avatar
well lucky for me its mine right? It will never be original again any way so that is why I cut it. to each his own and thank you for your kind words.
1969 C20 3/4
ΜΟΛΩΝ ΛΑΒΕ
Old 11-08-2010, 10:51 AM   #5
Liz
Catchy title goes here..
Liz's Avatar
Please review the site rules before posting again. Its fine to be a stock guy, not so fine to be rude about it.
Thanks!
Liz is offline   Reply With Quote
Old 11-07-2010, 11:12 PM   #6
stich626
I'd find a way to support the back of the radio.. the head units get kinda hot..
and that rubber support will not like it..
radio shack and others,maybe lowes/home depot too.
it'a a 3/4" wide strap that has holes in it every 1/2"
stich626 is offline   Reply With Quote
Old 11-08-2010, 12:21 AM   #7
RIA69
RIA69's Avatar
that's what I was going to do, I thought I had some laying around but come to find out I don't so this is just a temp thing. the rubber piece is actually and old rubber PCV grommet from a valve cover that I no longer needed so it should be OK for a little bit heat wise. Or so I hope anyways
1969 C20 3/4
ΜΟΛΩΝ ΛΑΒΕ
Old 11-08-2010, 11:35 AM   #8
MrDude_1
your stereo probably came with a lug that can go on the back.. it should look like a big thick pin.
if you get a rubber grommet that fits that pin, you can make a simple bracket with a hole in it.
mount the bracket under the dash, and when you slide the radio in, the pin will go in the hole and support the back of your stereo.
if you dont mount the back of it, it will eventually break either the radio mount sleeve, or twist the dash (or both).
MrDude_1 is offline   Reply With Quote
Old 11-09-2010, 12:22 AM   #9
kalirodding
CLASSIX Truck Club
Wasn't trying to be rude, geez. Some people need thicker skin I guess. I apologize if I insulted anyone.
Old 11-09-2010, 10:29 PM   #10
RIA69
RIA69's Avatar
no insult taken here trust me I HAVE thick skin, I have to to deal with the crap I do everyday. that's why I posted the smart a-- comment. no harm no foul.
1969 C20 3/4
ΜΟΛΩΝ ΛΑΒΕ
Old 11-09-2010, 11:43 PM   #11
lilpoindexter
lilpoindexter's Avatar
My '78 had the bezel cut for a radio...If it still had the OG radio, I would have put the radio under the dash, or in the glovebox...it was already cut so I just put a nicer radio in it...I bought a kit from crutchfield...it came with a thin gage sheetmetal bracket for the back, that I supported from some nearby bracket, to prop the radio up. you can use any little piece of sheet metal, or even that plumber's strap stuff.
lilpoindexter is offline   Reply With Quote
Old 11-13-2010, 02:18 AM   #12
Bad70sbchevy
Bad70sbchevy's Avatar
A support strap would be a good idea, but you dont need one. I'm running mine without one and its holdin up well.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 11-26-2010, 07:42 AM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
i put a strap on mine as i find sometimes the radio must bounce as the cd skips as the truck bounces
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 12-14-2010, 07:14 PM   #14
Andy4639
Old member
Andy4639's Avatar
Talking Re: took the leap. Cut my dash.
Nice job. I would put a strap on the back. My 71 had a place already there for the factory speaker mount. I used it to support the back of the radio.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
