11-08-2010, 01:38 PM | #1 |
5" drop and frame notching
To those you out there that lowered the rear of their trucks 5" (or more) how close is your frame to axle clearance if you did not notch the frame. Did you just make the leap and notch the frame?
I would like to drop my 67 truck 3.5" front and 4-5" rear and in my measurements I come up with 2 3/4" gap between the frame and the axle tube with a 4" drop. I really never liked the idea of cutting the frame on a truck that will have a tow hitch, at least not without alot of frame reinforcement. Comments....
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
11-08-2010, 01:47 PM | #2 |
Master Procrastinator
Re: 5" drop and frame notching
don't worry about it with that setup, not sure of the axle clearance but there are plenty of guys running the 4.5/6 drop setup without the c notches even
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
11-08-2010, 02:44 PM | #3 |
11-08-2010, 04:15 PM | #4 |
I'm running a 5" rear drop with no issues except my axle tube hitting the exhaust. That's only because the moron that ran my exhaust was...well.....a moron.
11-08-2010, 04:32 PM | #5 |
Running a 6 inch spring and no notch no problems at all of bottoming out.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
11-08-2010, 05:52 PM | #6 |
Tot Roddin'
Agreed.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
11-08-2010, 07:01 PM | #7 |
Junior Member
What does adding a 2" lowering block do for the need to notch when running a 5" or 6" lowered spring?
frontstreetcycle on Instagram |
11-08-2010, 08:07 PM | #8 |
11-08-2010, 10:48 PM | #9 |
Thanks for the response. I talked to Jeff @ CPP and he setting me up with 2.5 drop spindles with 1" drop springs then 4" drop HD springs in the rear. If I want to do the extra 1" in the future I will add a block.
11-08-2010, 11:45 PM | #10 |
do mind sending me a pm with rough price for the kit. i'm trying to save up and convince the wife
