11-09-2010, 09:32 AM | #1 |
Hydroboost + Hydrualic Clutch?
Hello there!
So I'm putting a hydroboost setup in my '66 Panel, however I'm running a manual transmission with a hydrualic clutch (which I haven't picture up yet either. ('73 SM465). I did find this thread - http://67-72chevytrucks.com/vboard/s...ght=hydroboost that helped a lot, but I'm not exactly sure if there is enough room to mount the clutch master cylinder? Has anyone done this?
1966 C10 Panel (3/4 Ton 4x4 Conversion) 2001 K1500 Silverado Last edited by Fursphere; 11-09-2010 at 10:02 AM. |
11-09-2010, 10:53 AM | #2 |
1961 crewcab
Re: Hydroboost + Hydrualic Cluth?
there are a couple guys on here that have used hydraulic clutch w/ power brakes, if I can find the pics/thread I will post 'em up.
basically they just space the brake or clutch mc out far enough with a bracket to clear the booster, or in your case the hydro boost system. they use a modern/aftermarket hydraulic clutch master cylinder.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
11-09-2010, 01:35 PM | #3 |
Captainfab make a killer set up for that....
11-09-2010, 06:41 PM | #4 |
1961 crewcab
check out this thread:
http://67-72chevytrucks.com/vboard/s...draulic+clutch also check out the link that captian fab put on post #4
11-09-2010, 09:58 PM | #5 |
So it looks like I need to build a bracket to move the hydroboost setup away from the firewall to make room for the clutch master cylinder? Correct?
Or relocate the clutch master cylinder and under dash pedal linkage somewhere else....
1966 C10 Panel (3/4 Ton 4x4 Conversion) 2001 K1500 Silverado |
11-09-2010, 10:07 PM | #6 |
Found this thread with some creative searching based on the threads you linked...
http://www.67-72chevytrucks.com/vboa...aster+cylinder I think thats the direction I'm going to take. Thanks again!
11-10-2010, 12:47 AM | #7 | |
60-66 Nut
Before you go ahead and purchase that one, I would suggest either contacting Sleepysal or check out his other threads to see if that setup actually works as intended.
