dynamat options??
i cant find it now, but i saw a thread that talked about other sound and heat deadening materials, even some at home depot that were just as good but a lot cheaper. does anyone know of any?
Senior Enthusiast
Re: dynamat options??
Perhaps post #3 on the attached thread is what you're looking for:
http://67-72chevytrucks.com/vboard/s...ght=HOME+DEPOT |
Fat Mat
Same thing i used. The smell is bad for a while but once it airs out it is ok.
I also used FATMAT 80 mil from ebay . I used alluminum tape from HomeDepot on all edges and seams I did notice any odor.
I LOVE BURNOUTS ![]() ![]() NO BOZO's |
Yeah Fat Mat for hard wood floors and like badriand said let it air out, A friend of mine that installs stereos used it when people had a low budget built works great or try Solid Sound same thing
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project) It's your ride build it the way you want !!!!!!!!!! ![]() Last edited by sandnuriz; 11-11-2010 at 11:04 AM. |
Resistance is Futile
others have mentioned 'Peel and Seal'.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
I bought a gallon of Edead v3 a month ago and applied it with a paint brush. It was enough to cover my firewall and floors with 3 coats. Here is the site where I bought it from.
http://www.edesignaudio.com/index.php?cPath=1_24
66 suburban 51 Merc 2 door coupe 38 Chevy Business Coupe (gf's) 76 Airstream Sovereign |
#9 | |
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
I was really impressed with the amount of outside noise it reduced. I did the firewall, floor and back wall behind the gas tank. I was going to apply it inside the doors but realized it would be too messy so I will be ordering their roll on type for inside the door panels. I used a paint brush to apply. Make sure each coat is completely dried before applying another. The guy said I could use a gun to apply it and just thin it down with water. I can't remember what the ratio was but if you call them they are very helpful.
