Pickup coil noise
Howdy. Just finished (with some help) a new intake manifold gasket. Also put on a new cap and rotor. Now - sometimes - I have a tapping, clicking noise that somebody said was probably the pickup coil. Seems like it is coming from the distributor.
Truck runs fine. This is a 72 with a 90 model 350 TBI. Might it reseat itself as the parts guy told me? Might I be left on the side of the road sooner instead of later? Just not sure what to think. Runs good but has that noise. Thanks for any ideas. |
Re: Pickup coil noise
Bout the only reason I can think of for a tapping noise from the dist is due to worn bushings unless something got installed incorrectly or something loosened up. Take a relook at installed items. Look for any interference from the rotor and capand wiggle the shaft from side to side. It should be pretty tight.
In the beginning of a change, the patriot is a scarce man, brave hated and scorned. When his cause succeeds however, the timid join him , for then it costs nothing to be a patriot. I am a revolutionary...so my son can be a farmer...so his son can be a poet. If there must be trouble, let it be in my day, so my child may have peace... 72 short step w/ 388 /4l80e/ and 3.08 gears. |
Take a long piece of old garden hose or use a long wooden dowel to use as a stethoscope to pinpoint exactly where the noise is coming from. Don't laugh. It works.
Will do. Been trying to read old posts about this but haven't seen anything about the noise. It's a spark sound but it sorta sounds like a June bug hittin the glass.
Might be a spark plug wire not seated or crack in cap, you could fire the truck up in the dark see if you can find a plug wire jumping the gap some place it isnt suppose to be.
