Old 11-11-2010, 06:17 PM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Steelie question
Is the 6 lug on our 60-66 2WD trucks the same pattern as the K5 Blazer 6 lug wheels?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 11-11-2010, 06:31 PM   #2
62 short step
62 short step's Avatar
Re: Steelie question
Yes it is.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 11-12-2010, 05:29 AM   #3
62 Longbed
62 Longbed's Avatar
Thats whats on my 62 for wheels ..
62 Longbed is offline   Reply With Quote
Old 11-12-2010, 08:24 AM   #4
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Same here .... I got a set too
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 11-12-2010, 11:36 AM   #5
61_FL_Apache
Who Me?
Thats what im looking for.. How wide are yours? Im looking to do 10's in the rear and 8's in the front if I can find them.
Steve
2001 Blazer 4D 2WD
Old 11-13-2010, 06:07 PM   #6
62 Longbed
62 Longbed's Avatar
Mine are 15x8's all the way around ... Stock width .. I'm running 235-60R-15 on the front with 305-50R-15 's on the rear ..with stock beauty rings .. I'm gonna change to 275-60R-15 's when its time to replace .. Availability and I want a little taller profile ..
Old 11-13-2010, 06:57 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
Nice looking truck.
Old 11-14-2010, 02:34 AM   #8
62 Longbed
62 Longbed's Avatar
Thanks markeb01 for the compliment !! You also have a nice truck !!! Simular to the one my father had as I was growing up .. Brings back good memories .. Very Nice !! I may have a 63 GMC Longbed 1/2 ton , V6 , A/T , Custom .. in the next month or so .. I have my fingers crossed , just need to gather up the money ..
Old 11-14-2010, 08:28 AM   #9
skysoldier173rd
skysoldier173rd's Avatar
Even though they both have the 5.5 bolt circle, isn't the center bore size different (smaller) on the newer trucks than ours? If so, anyone know what year the change(s) occurred? I heard you can get 1/4 inch spacer plates to get the wheel out far enough so that center bore size is not an issue. Also like info on that if anyone knows.
www.picturetrail.com/skysoldier173rd
skysoldier173rd is offline   Reply With Quote
Old 11-14-2010, 10:11 AM   #10
markeb01
Senior Enthusiast
markeb01's Avatar
According to post #11 on the following thread from Raycow, the wheels to use are 71-87 (4x4). The 88 and up wheels have the smaller center hole:
http://67-72chevytrucks.com/vboard/s...d.php?t=430426
Personally I would be reluctant to use spacers as they may put more strain on the studs, and may also provide insufficient engagement unless the studs are replaced with longer units.
Old 11-14-2010, 12:58 PM   #11
lakeroadster
I share Mark's concerns unless you buy a quality set of spacers made for the specific application, like these: http://www.wheeladapter.com/wheel_spacers.php
Using these you don't lose the hub-centric mounting advantages. I am betting though if the "new wheels" have a smaller hub than the existing truck hub that the spacers would have to be thicker than a 1/4".
With the cheap spacers like these http://www.jegs.com/i/Mr.+Gasket/720/2376/10002/-1 you loose the hubcentric advantages.
lakeroadster is offline   Reply With Quote
Old 11-14-2010, 07:58 PM   #12
61_FL_Apache
Who Me?
More great info. Im still running drums on the front and plan to keep it that way. Hopefully the stock wheels wont be an issue.
Steve
2001 Blazer 4D 2WD
Old 11-15-2010, 07:28 PM   #13
62 Longbed
62 Longbed's Avatar
I'm still running the stock drum setup frt. & rear .. No Problems .. Even when upgrading to a newer frt. suspension or just doing the disc only conversion all should work well together since the stock Rallys were 99% of the time always on a model with factory disc exactly like we end up swapping over to .. 2 whl or 4 whl drive .. There is enough clearance and depth , for rotor and caliper offset ...
Old 11-16-2010, 06:05 PM   #14
61_FL_Apache
Who Me?
Now I just need to find a set.
Steve
2001 Blazer 4D 2WD
Old 11-16-2010, 10:28 PM   #15
iiizman
iiizman's Avatar
Lake Roadster was right about wheeladapter.com, even if you don't need the adapters-talk to Fred over there, he is a cool old guy that ran around with Shelby in his hey day and has good stories. He makes the adapter as you need them.
Bad Decisions usually make for Good Stories.
iiizman is offline   Reply With Quote
