![]() Join Date: Nov 2009
1972 2wd cab for patches
1972 cab for patches. like most cabs the inner and outer rockers are rusted, the bottom cab corners are rusted, and the cab supports are rusted as well. But the rest of the cab is solid. All around both windows is solid. The corners where the bed sometimes dents the cab are only slightly dented. Let me know what you need. Depending on size you might just need to pick them up. I already cut a couple of pieces off.
Re: 1972 2wd cab for patches
bttt
i sure wish you were closer to socal. I really need the top half. My 72 is rusted out all around the driprails. I want to cut my cab as if chopping the roof off. yours looks pretty good in the pics..
all of the top is solid. Might have a few dents here and there. There is a feller that want's the passenger side drip rail I think. So that would kinda ruin what you would need if he decides he needs it.
I would like the inside roof above the windsheild.. how much + shipping to Kansas City MO 64118
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074 Toys: 2014 Dodge Ram 1967 SHORTBED |
![]() Join Date: Feb 2010
I'm interested in the center section of the dash to fix a mangled radio cutout on mine. Could use the lighter bezel thingy too. zip is 94559
Replied to inquiries via pm. Thanks
(007) aka Houdini
![]() Join Date: Mar 2010
pm sent!
Live life one day at a time! |
up T T T
taking it to the top.
how much for both sides shipped to 29702
sorry it's taken me so long to get to you. I removed the drip rail from the corner back on the passenger side. It was from the joint at the corner back. What is it that you need exactly? I have one side that is still totally intact. The other has the drip rail removed. Thanks.
it is the upper a-pillar area that joins the center area, where the about 3 peices lap,i have rust bad in that area, also down the pillar toward the bottom, i might can find a pic of my actual truck and send to your email site if that will help, one thing is i wouldnt want you to cut it untill last, cause you may can sell whole roof.i can send my truck pic if needed to show area
