How much will lowering the rear cost me?
Title says it all. Im working on the rear end of my truck IE: bed, frame, gas tank install, all that good stuff. Wanting to lower it while im at it... Thought it was gonna be cheap but got my bubble busted. (thanks CURSED GEARS) anyone got good cheap but safe ideas or great places to go?
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: How much will lowering the rear cost me?
Uh,... what are you working on?
67-72,... I assume? Coil spring? Leaf spring? 1/2 ton? 3/4 ton?
#3 | |
So im opening my mind a bit and trying to workout the design scheme. |
The Older Generation
Well, it really depends on how low you want to go. If you have coils & only want to go down a couple of inches get some 2" x 2" 1/4" wall square tubing, cut off two 6" pieces and drill holes in them for the "U" bolts, buy new 2" longer "U" bolts (about 30 bucks) and bolt it together... If you want more you will have to go to new drop springs, about 90 bucks I think. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-12-2010 at 02:29 PM. |
go real ccheap could cost you a truck or a life
theres 40year old worn bushings in trailing arms and panhard bars they good fer you? a 40 year old brake hose that good fer ya?? 40year old shocks they fill yer bill? i'm sure those 40year old brake parts r jjust tiptop for your application doing a job is worth doing it correctly some people believe
#6 | |
big old burb in primer.lot of work to do. |
#7 | |
![]() ![]() ![]() Last edited by LeatherMan69; 11-12-2010 at 03:20 PM. |
we cool like that I got your back.LOL
#9 | |
#10 | |
4/6 is a good street driving drop.
Use 6" drop rear springs, rear shock relocators and good quality drop shocks. You will also need an adjustable panhard bar to re-center the rearend after the drop. Remember the springs are 6" lower than "new" springs,... not your 40 year old sagging springs. So just throwing a tape up next to your truck and saying "4 inches lower will be perfect", may not be an accurate statement. Go for the 4/6 drop!
#12 | |
![]() Join Date: Oct 2007
Old Skool Club
![]() Join Date: Jun 2001
When I did my truck.....okay my cousin did the wrench-pulling.....I spent almost $2K. He gave me a real bargain for his labor. It would have been an easy 2 to 3 times the price I paid him at the shop he works at (he charged me $300 for his labor and took all week). Anyway, the front end was completely redone....upper/lower control arms and bushings; upper/lower ball joints; tie rod ends...inner and outer; pitman arm; idler arm; ECE drum to disc conversion and all 4 springs; stock height springs up front and 4-inch shorter ones out west; Adjustable track bar (panhard rod), and rear shock mount relocators. All parts were MOOG or Delco.
When all was said and done, a trip to the alignment dude and it all went back to factory OEM specs.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Hey guys, I used a kit from Brothers. I guess it was a little more spendy then leatherman wants to go. Ive read on here about people using Jeep springs to lower their trucks. I'm not familiar with that. Can someone chip in about that? Amount of drop, price, etc? Thanks.
And don't worry, Leatherman will do it safely. Whats the point of looking cool if your dead a short time later? Lowbuck done right can be just as safe as emptying your account. |
#15 |
You guys got some good resonabley priced vendors in mind? 4-6 drop it is my friends... if im gonna do mind as well have it matter eh?!
#16 |
Jeep springs eh? never heard that. And yes dead in a bada$$ truck isnt in style, and not a trend i plan on setting
#17 |
ECE (www.EarlyClassic.com)
They are the only company I use for 67-72 suspension stuff. www.PerformanceOnLine.com also has great prices and service
#18 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
4-6 drop parts list. (assuming your ball joints, tie rod ends, and control arm bushings are in good condition)
Front 2 1/2" front disk brake conversion kit 2" front lowering coils 2" front lowering shocks Rear 4" rear lowering coils 2" rear lowering blocks "C" notch kit super panhard bar kit shock relocator kit 4" rear lowering shocks (because I haven't found 6") 2-4 drop parts list depends on if you want to go front disk brakes or not. if front disk brakes then all you need for the front is a disk brake conversion kit with 2 1/2" lowering spindles. if not changing to disk, then what you need is 2" front lowering coils and 2" front lowering shocks. Rear 4" rear lowering coils 4" rear lowering shocks you may get away with just an adjustible panhard bar and not need the shock relocator kit or super panhard bar kit. I would lower it and look at it to make that judgement. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 11-13-2010 at 03:07 PM. |
