Need some Trans info and help
ok guys I need some help here.
I have an 85 2wd 1/2 ton with a 305/th350 combo. The trans is blown. I have an opportunity to pick up a 81 c-10 diesel missing a bed for $150 but the drivetrain is complete. Its an automatic in the thing so does can anyone tell me what trans is in this thing, and will it bolt up to my Gas 305 without any problem? Thanks in advance Gregg
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!! |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Need some Trans info and help
you would have to look under the truck to see what trans is in there. Its identified by the pan/ Im thinking the diesels came with a th400 back then so you would need to swap driveshafts and i believe the kickdown cable is different. Also the 400 does not use the vacuum advance that you would have to block off at the carb
this link helps identify the trans by the pan http://www.nastyz28.com/chevy-transm...tification.php
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
I don't think the tranny swaps. The diesels where based on a 350 Olds block that had a different bellhousing bolt pattern. IIRC
