made in america
what track bar
hey fellas. i got the 66 lowered 3/5 right now and im having a small problem with axle placement. i know i need a new track bar but im unsure of wich one to get. brothers has a 24 inch and an adjustable that they say is ment for trucks lowered 4 inches or more. mcgaughys also has an adjustable track bar. what are yall runnin? right now my track bar is parrallel with the axle so its pushed it out to the passenger side pretty far. thanks for the help!
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes. sounds good 1964 c10-283 powerpack, 3 on the tree ![]() 2004 corvette- lowered, borla, tuned. slow ![]() my old girl 1966 c10- 305v8, t-5 sold |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: what track bar
I like the Super Track Bar from ECE, (Early Classic Enterprises).
It's extra long to limit lateral axle movement. They also come powdercoated. Check out www.earlyclassic.com.
#3 | |
![]() Join Date: Sep 2010
Re: what track bar
made in america
Re: what track bar
thanks for the help guys. think this same one will work if i go any lower?
Re: what track bar
yes.
made in america
Re: what track bar
awesome. thank!
Redneck Hillbilly
Re: what track bar
Just bookmarking, gonna need one of these too. Thanks
Re: what track bar
hey how do these install am i supposed to drop the truck to its lowest point or ride height. When its aired out the drivers side fender hits the tire thanks, Tony
![]() Last edited by 62 Bowtie; 11-17-2010 at 09:23 PM. |
Re: what track bar
I beleive your looking to adjust at a happy medium between your lowest drop point adjust to clear and as close to center ( wheels in fenders) at your ride height.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Re: what track bar
I believe your looking to adjust at a happy medium between your lowest drop point adjust to clear and as close to center ( wheels in fenders) at your ride height.
Re: what track bar
John you don't know how much we appreciate you bringing your engineering skills to bear on some of this issues!!
![]() -Tad
292 + TKO500 |
Re: what track bar
Well yes, that's the secret ingredient. Look at real world trucks with suspension modifications and see just how many of them actually have the track bar horizontal at ride height. Once you get away from horizontal, the amount of lateral displacement starts increasing quite rapidly.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
Re: what track bar
I installed the rearend centered at ride height.
The Super Track bar is much longer than the original panhard bar,... and should help with side-to-side movement. I think mine only shift 3/8" when I air out the bags.
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: what track bar
cpp has this one on ebay for $109
http://cgi.ebay.com/ebaymotors/1963-...Q5fAccessories
#15 |
Re: what track bar
Here is one for $59 bucks!
Early Classics P/N 912-6572PB Adjustable panhard bar kit '65-'72 C-10 w/Bushings http://www.earlyclassic.com/catalog.aspx Under "Choose Catagory" Select "Panhard Bars" And one other note: For a "Static" dropped truck you do not need a "Super Track Bar", there simply isn't enough suspension travel to justify it. You just need an adjustable track bar to dial the rear end back over to the center. Hope this helps. Last edited by lakeroadster; 01-20-2011 at 09:07 AM. |
#16 |
Re: what track bar
I'm having a difficult time finding the trailing arm kit that uses the trailing arm for the lower mounting bracket for a 3/4 ton truck. Lots of kits for 3" axles, but can't find one for 3-3/8" axle tube.
The inner diameter of my u-bolt is 3-1/2"
#17 |
60-66 Nut
Re: what track bar
Are you wanting to mount your panhard bar to the passenger side trailing arm mount?
#18 |
Re: what track bar
Not necassarily.
I've seen posts by you where you suggest just cutting the panhard bracket off the Eaton. That was my plan all along. I have a local spring guy that will be making my new U-Bolts for $17.50 ea. Both sides bolts, nuts, and washers for $35. I was going to wait until I got your perches before I get them. But I started thinking about maybe just getting the adjustable panhard/trackbar kit where you get the u-bolts and all. - just researching - that's all. I just find it interesting that the 3/4 ton stuff is so limited. Even the U-bolts aren't as easily found as for the 1/2 ton trucks. LMC is the only one I've found so far that actually lists 3-1/2" u-bolts for C20's Like I said, I'll most likely just cut the panhard bracket off the eaton, I just started thinking if there was a kit, that even included the u-bolts, it may save me some work.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 02-06-2011 at 01:29 AM. |
#19 |
60-66 Nut
Re: what track bar
Yes I understand the desire to just buy a kit with everything needed. But as you said, there really isn't a kit for the C20's. Especially not for switching to a 14 bolt rear differential.
#20 |
Re: what track bar
Someday, maybe.
#21 |
60-66 Nut
Re: what track bar
It's a definite possibility.
I know someone that can make the trailing arm mounts ![]()
#22 | |
Re: what track bar
