engine choice
right now i have a 350 with a blower on it. i am looking at turning it into a stroker or going to a bbc. i want to get around 600hp. any opinions would be great. as far as bbc i would go with a 502 or a 572. the stroker with the blower would be a 383. also i want to keep the truck drivable. the truck has a 700r4 and 3.73 rear end.
#2 | |
Re: engine choice
Re: engine choice
ok thank you. do you know what hp would be a nice driver with the 502?
By the end of the day trying to get that many ponies out of a 350 on a blown set up you would prolly be better off getting a good 502 selling your current set up and make up the difference. I'll help out by offering you $5 for your current set up
My build thread for Project TiC TaC/Jazzmin Oh Yeahhh Cheap work is never good and good work is never cheap. Lesson = learn to do it all the right way on your own. ![]() SqueegeeMan |
Re: engine choice
Nope. Not familiar with the 502 but my 572 is 620hp, 700 ft lbs torque and it's got a 3 year warranty!
Re: engine choice
im not keeping it a 350 if i do. i am going to make it a 383 or 400 so it wont be to bad to get the power out of it. the motor has alot of high end parts on it like dart heads so all i need is some machining and a new bottom end.
Big Red - Now its a SWB!
Re: engine choice
how much power you putting out now with the blown 350? How much boost you running?
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
Re: engine choice
its an older rebuild but im guessing 400 to 425 and i dont know the boost im thinking only about 4 or 5 pounds
Re: engine choice
how is that 572 for driving in traffic and just idling around town? also is it just pump gas? did you get it right from GM?
![]() Join Date: Oct 2005
Re: engine choice
I have a 383 with small 142 weiand on it that fits under the stock hood that is making just north of 500 hp and could easily by a daily driver if I wanted. I've put a good 6k miles on it and been in bumper to bumper traffic on +100 deg days.....no problems. The 142 is a little small for a 383 but you could probably put a 177 on it with a cowl hood and easily make 600 hp. If you want to poke a hole in your hood and do a 671, 600 hp is even easier. Can't remember which magazine did it, but they did a 383 with a Weiand 177 on it and made over 600 hp.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Re: engine choice
I live in Tucson so...hot summers! Around town summer or winter it runs just fine, but it's got a lumpy idle, so it's set to idle between 850 and 900 rpm. I'm running a 2800 rpm stall converter so it's just freewheeling below that and it doesn't matter where the idle is set. GM set it up to run on 94 octane pump gas (9.6:1 compression). If I keep my foot out of it mileage is about 10 mpg, but when I let it rev, you can watch the gas gauge fall. Walked down to my local chevy dealer and ordered it right over the parts counter...took 3 weeks.
Re: engine choice
i have the same blower setup as you got in your pic there but just a 350. so i will take what you said into consideration. i like the look of the blowers. thank you
#13 | |
![]() Quote:
All that said, using a smaller blower and settling for 500 Hp and you probably have a reasonably streetable truck. Settling for 500 Hp. ![]() ![]() ![]() ![]() |
Re: engine choice
that is true but i dont believe the crank, rods, and pistons wont be stock im taking the motor into one of the local race shops and get then to build it and tune it for the blower so all i need to do is take it home and drop it in the truck. i plan on taking the truck to the track because i always wanted to go and now have something that i can take.
#15 |
![]() Join Date: Aug 2004
Re: engine choice
Anyone else hearing LSx, LSx, LSx!?
Must be just me....
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#16 |
![]() Join Date: Mar 2010
Re: engine choice
+1 You can pick up a salvage 6.0,stick a camshaft in it, and a few other upgrades,and get you over 500 h.p.. A whole lot cheaper than any 502 or 572, and drive it anywhere, with great fuel mileage.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
#17 |
Re: engine choice
I may be wrong but I thought the 502/572 were like over $10K. You could build a screaming cammed, turbo 6.0l for half that i would think.
#18 |
Re: engine choice
how much is a lsx? what is the size?
#19 |
Re: engine choice
LSx come in a variety of sizes, but in liters, ie 4..8,5.3,6.0 ( LQ4 and LQ9), 6.2. Some are called LS1, LS2, LS6, etc.
You might want to look at Thealien's write up on them to get the full story, or you can also visit this forums engine section under LSxSwaps, for more better information. I have a 4.8 in my 65, runs around 300HP FI and stock tune basically. The 6.0l can get over 400HP stock, with over 500 easy with cam, headers and tune. then you can put a turbo on it and go nuts with somewhere north of 650, all without selling the farm and the kids. That is if you know how, what to do and all. I hope I have peaked your interest. Might be a cheaper or better route for you to get what your looking for. I have seen some LSx motors for around $2K pull outs and then throw another $1k at them in tune and cam and 500+ HP is all over it.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 11-22-2010 at 06:58 PM. |
#20 |
Re: engine choice
how easy is it to come by a LS2?
#21 |
Re: engine choice
ummm, not as easy as a LQ4 but these are what had the LS2
* 2005-2006 Pontiac GTO * 2005-2006 Chevrolet SSR * 2005-2007 Chevrolet Corvette * 2005-2006 Holden Special Vehicles Clubsport (Z Series) * 2005-2006 Holden Special Vehicles Senator (Z Series) * 2005-2006 Holden Special Vehicles Coupé4 AWD (Z Series) * 2005-2006 Holden Special Vehicles Avalanche XUV AWD (Z Series) * 2005-2006 Holden Special Vehicles SV6000 (Z Series) * 2005-2006 Holden Special Vehicles Maloo (Z Series) * 2005-2006 Holden Special Vehicles Coupé GTO (Z Series) * 2005-2006 Vauxhall Monaro VXR * 2005-2008 Holden Special Vehicles Clubsport R8 (Z Series, E Series) * 2005-2008 Holden Special Vehicles Grange (Z Series, E Series) * 2005-2008 Holden Special Vehicles Maloo R8 (Z Series, E Series) * 2006-2007 Cadillac CTS-V * 2006-2009 Chevrolet TrailBlazer SS * 2008-2009 Saab 9-7X Aero LKQ in DFW Texas lists 3 for 05-06 GTO, 3200-3600.00 28K-70K miles.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 11-23-2010 at 03:13 PM. |
#22 |
Re: engine choice
i found 2005 Cadillac CTS-V 5.7L LS6 ENGINE AND T56 6-SPEED MANUAL TRANSMISSION on ebay complete with everything for 6000 with 30K miles. it says it has 405 horse power is this correct?
#23 |
Re: engine choice
I believe it is the same horse as the first gen z06 corvettes, The price sounds high to me..Just buy a 6.0 truck engine and swap in some upgrades.
#24 |
Re: engine choice
Yea, that is alot of coin, I agree with gearys.
#25 |
Re: engine choice
Go LS engine, you'll be happy you did. Much easier to get the power, plentiful parts and more reliable, better mileage, better drivability....Plus the cool factor:
