Old 11-13-2010, 04:14 PM   #1
remist17
remist17's Avatar
Flames through the CARB !!!
Guys and Gals need some help
Just tried starting a 383 storker project and the motor runs for about 3 seconds dies. Starts back up runs 2 seconds dies, then just cranks and flames come from the carb.
Checked all wires and they are running correct. Setup timing to be 0 and went all th way up to 12 deg. Still doing the same. Getting about 5psi of fuel pressure. Pulled the bowl and foud #65 jets in the carb.
My setup
383 stroker
280H Comp Cam
Vortech heads
Airgap edelbrech intake
4160 Holley Carb
HEI dist.
ALL new never ran.
Please help me out, any suggestion on how to make the engine run and without flames.
2013 Chevy Silverado, Z71, 5.3L, 4 door
2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40
Support the Troops.
remist17 is offline   Reply With Quote
Old 11-13-2010, 04:17 PM   #2
remist17
remist17's Avatar
Flames from the carb
I am listing this also in this part of the forum as I need a quick response. I also posted in engine section.......
My setup
383 stroker
280H Comp Cam
Vortech heads
4160 Holley Carb
HEI dist.
Support the Troops.
Old 11-13-2010, 04:43 PM   #3
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Re: Flames from the carb
it back fires so its ignition related
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 11-13-2010, 04:51 PM   #4
remist17
remist17's Avatar
would the distrubuter play a role in the backfire. I picked this one up from a buddy and he was not sure what it went to. IT is a chevy HEI distributer and appreared to be the standard one
Support the Troops.
Old 11-13-2010, 05:21 PM   #5
ont_guy_38
ont_guy_38's Avatar
Sounds like maybe the distributor is out a tooth
ont_guy_38 is offline   Reply With Quote
Old 11-13-2010, 05:28 PM   #6
HOGDADDY
HOGDADDY's Avatar
+2^ or even a crossed plug wire.
HOGDADDY is offline   Reply With Quote
Old 11-13-2010, 05:36 PM   #7
mongoose
mongoose's Avatar
180 out?
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 11-13-2010, 11:11 PM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Originally Posted by mongoose View Post
180 out?
yeah^^^
Old 11-13-2010, 05:56 PM   #9
ont_guy_38
ont_guy_38's Avatar
Anyone of the above...lol
Old 11-13-2010, 06:00 PM   #10
LONGHAIR
Re: Flames through the CARB !!!
It sounds like you have at least one valve too tight. Check that firing order one more time.
UPDATE: Merged, Please don't do this
XIV. Multiple Posting - It is simply not acceptable to post your question more than once, or to post it in more than one forum. Choose the forum that your question or post best fits in, and place it there and only there. If, after posting, you feel it should be in another forum, private message the forum Moderator and ask if they would move it for you.
One of the most annoying things that happens around here
"I know that it's against the rules......but I'm gonna do it anyway"
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 11-13-2010, 06:07 PM   #11
Arkansas50's
Arkansas50's's Avatar
I had one do that. The distributor was 180 degrees out.
1950 Chevy 3600
1951 Chevy 3100
1954 Chevy 3100
1954 Chevy 6400
Arkansas50's is offline   Reply With Quote
Old 11-13-2010, 11:29 PM   #12
Youngbuck7072
Youngbuck7072's Avatar
is it a new carb?
........................ __
............._______|__\____
............|_({})______({})]
................(O)..........(O)
Youngbuck7072 is offline   Reply With Quote
Old 11-14-2010, 11:46 AM   #13
piecesparts
Parts and more parts
piecesparts's Avatar
I would check the distributor's alignment for a start and then: Are you sure the rocker arms are adjusted properly? If they are too tight, then you could be getting backfire and the engine will not start.
Frank
Old 11-14-2010, 03:16 PM   #14
remist17
remist17's Avatar
how do I check on the dist if its 180 out? Do I just spin it 180 deg and try it again?
I checked the rods prior to installing the motor and set them and had someone else check them who had done it before. They were good but Ill check again/
Carb is a new Holley 4160
Support the Troops.
Old 11-14-2010, 03:30 PM   #15
80chevyshortbox
80chevyshortbox's Avatar
i had the same problem when i started my 350. turns out that my timeing was 180 degress out and i also had some spark plugs mixed up.
80chevyshortbox is offline   Reply With Quote
Old 11-14-2010, 03:44 PM   #16
80chevyshortbox
also to check if your distributer is out 180 degress take out the number 1 spark plug and the distribiuter put your finger in the hole and crank the motor untell you feel air blow out the hole then drop the distributer back in and it should drop right into the number one position and it should fire right up if all your spark plugs are hooked up right.
or it was something like that im shure if i told you worng some one will tell you the right way to do it haha. my brain is kinda a bit fuzzy i have not done it since i was 14 hahaha.
Old 11-14-2010, 03:49 PM   #17
justinburnett
justinburnett's Avatar
it's firing when the intake valve is open, presumably, so i'd flip the dist around and try it that way. Don't know about the jets in your bowl, that doesn't sound like an indication of a good build, but I can't help you there.
justinburnett is offline   Reply With Quote
Old 11-14-2010, 07:21 PM   #18
piecesparts
A couple of things that I would do. (#1) bring the #1 piston up to TDC on the compression stroke. Then look at the balance and make sure that your timing mark is at the pointer. Next, check the distributor and see where the rotor is pointing. That will tell you is you are out of synch.
(#2) You said you chaecked your rods---OK---Now did you check your rocker arm adjustments for proper length. There is a trick to doing it on a cold engine, that inculdes rotationg the engine a couple cycles while you are doing it. You have to be careful that you don't compress the lifters too much.
Frank
Old 11-14-2010, 09:20 PM   #19
geezer#99
geezer#99's Avatar
If you've been backfiring thru your carb there's a real good chance your power valve in your new Holley is ruptured.
Old 11-15-2010, 11:22 AM   #20
remist17
remist17's Avatar
well kinda sad to say this.....
Looked at the engine last night..... well I left the washers on the carb studs and there was a huge gap between the carb and intake. I removed the washers and the truck started and ran ! Im stupid
Support the Troops.
Old 11-15-2010, 08:14 PM   #21
LONGHAIR
Well, that'll do it too....
Old 11-16-2010, 11:07 AM   #22
jchav62
1962 C-10
jchav62's Avatar
Next time someone asks this question, this will be the first thing suggested... I'm glad you got it figured out...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 11-16-2010, 05:05 PM   #23
remist17
remist17's Avatar
We started the truck and ran it to break in the cam. It was the first time I had to put hearing protection on with open headers....
I am thinking I should have gotten a quiter muffler !
Full build to come on the post
Support the Troops.
Old 11-16-2010, 05:12 PM   #24
justinburnett
That totally sounds like something I would have done.
