03-03-2003, 08:38 PM | #1 |
Member since 2000
torque converter bolts???
What bolts do you guys use? thanks
03-03-2003, 08:52 PM | #2 |
crank shaft bolts. I use arp. and on the flywheel I use grade 8 3/8" Aint broke nuthin' Yet.
'72 1/2 ton short box 468 BB forged crank/rods/pistons full roller. Msd 6 AL ignition turbo 400 tci. 2800 verter ladderbar/coil rear with currie built ford 9'' rear, 4.11 gears custom built rear frame tubbed, 33/19.50/15 rear m/t. m/t skinnies in front still under construction |
03-03-2003, 11:18 PM | #3 |
ARP
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
03-03-2003, 11:42 PM | #4 |
I agree. ARP even makes ones with irregular heads for externally balanced engines - in case you have a troublesome big block or a 400.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
03-03-2003, 11:57 PM | #5 |
its all about the +6 inches
I'm in the minority here I guess...I have stock bolts.
03-04-2003, 01:07 AM | #6 |
stock bolts are fine, as long as their new...bolts will stretch and get weak if tightend and re tightend...so instead of buying stockers..I go for the ARP, just because their a little stronger
03-04-2003, 01:16 AM | #7 |
14.1 @ 96MPH
I use stock GM bolts...mine are new, but that's namely because my 700R4's converter uses metric bolts.
Project1970 - LS1 Swap Complete! |
