Old 11-15-2010, 04:45 PM   #1
72chevyk10
I built it
72chevyk10's Avatar
Question locked hubs on freeway?
as you know, the bad weather season is coming. im wondering if its ok to keep the hubs locked with the x-fer case in 2wd while going 60mph? (info is for truck in sig.) will it hurt anything doing this? axle bearings, u joints, etc.?
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 11-15-2010, 05:17 PM   #2
Blazer1970
Blazer1970's Avatar
Re: locked hubs on freeway?
No, it wont hurt a thing. If you really have a 203 t-case, you shouldn't even have lockouts.
Blazer1970 is offline   Reply With Quote
Old 11-15-2010, 05:19 PM   #3
Thealien
Thealien's Avatar
On all my older manual hub vehicles that were daily drivers I used to lock the hubs at the beginning of winter and unlocked them in the spring. You could possibly wear some parts faster? I always kept my stuff maintaned and never had a problem. Someone else may have a different opinion?
Old 11-15-2010, 05:24 PM   #4
72chevyk10
I built it
72chevyk10's Avatar
as far as i know its a 203. and it doesnt engage unless the stick is in 4wd..
ok thats good to know. im pretty good at keeping the ol' truck maintained
Old 11-15-2010, 05:22 PM   #5
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
The only thing it will hurt is fuel mileage. If you have a NP203, hopefully someone has installed the part time kit in it so your drive line doesn't spin with the hubs unlocked. Since you plan on running the lock outs locked in, just double check all of your fluids to make sure they are full and not full of debris, or really old. You also might give your u-joints a once over to make sure there aren't any loose ones or anything strange. With the lock outs locked in during normal driving every day, you could start to see wear in these items fast because they aren't used to be turning a lot every day. Not really a big deal. Some of the newer trucks front drive lines are turning all the time, Dodges mainly 02 and up.
Ryan
1969 Chevy milk truck
Old 11-15-2010, 05:29 PM   #6
72chevyk10
I built it
72chevyk10's Avatar
good to know. yea last year i had to replace a couple of the front driveshaft u joints. the rest of them seemed good and tight. ill check all of them again though
Old 11-15-2010, 07:35 PM   #7
Mike C
Mike C's Avatar
The original T-case in a '72 would be a 205. But running with the hubs locked and the shifter in 2 hi shouldn't be a problem. My Jimmy cratered the rearend nearly 30 years ago, and my dad drove it in front wheel drive for at least 6 months. Just pulled the driveshaft and kept on going until he had a replacement.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-15-2010, 08:07 PM   #8
LONGHAIR
Your signature says Dana44 frt "factory locker".....I find that very hard to believe, especially with a 12 bolt and a clutch-type Posi in the rear.
What kind of differential is really in there?
If it really does have a true "Locker", as in Detroit (No-Spin), I would not run it with the hubs locked in in the road.
Buy running it w/o power coming to the gears from the driveshaft, it will "annoy the heck out of it". It would be clunking back and forth constantly. Every turn of the steering wheel would have it disengauging from one side to the other.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 11-15-2010, 10:03 PM   #9
swamp rat
swamp rat's Avatar
I agree with MikeC, My 72 has a NP205,
This is a pic of the NP205, look at the small plate in the center with the 3 bolts in it, the 203 is different, just crawl under and have a look.
http://media.photobucket.com/image/n...luck75/238.jpg
NP203:
http://www.hotrodders.com/forum/atta...?postid=297530
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-15-2010, 10:44 PM   #10
72chevyk10
I built it
72chevyk10's Avatar
yea. i made the sig a while ago.. and have since figured out its not a locker. its just a lockout. i forgot about that sorry bout the confusion.
Old 11-15-2010, 10:43 PM   #11
GM didn't put lockers in fronts of 4wds,or rears of 1/2s at all.We need accurate into to answer the question.It doesn't hurt to leave hubs locked in if it isn't a locker.People only run lockers in the front of off road only rigs.And,even then,most don't.
Old 11-16-2010, 01:42 AM   #12
CG
BlahBlahBlah
I had no idea it was OK to run like this. Even though Ive had 4X4 Chevy trucks for at least the last 15 years I really don't know much about how the drive train works.
I'm not an avid four wheeler, I just like the extra pull when I need it. Definitely gotten me out of a jam more than once.
Old 11-16-2010, 08:52 AM   #13
The original design for this type of 4wd was always locked in.Hubs to disengage for free wheeling were an after thought first made by the aftermarket.That's why they are called lock out hubs (or at least were for a few decades).There are listed as an option.U-joints,dbl cardons,and hubs wear out from lack of use...lube isn't spread around.
Old 11-16-2010, 01:05 PM   #14
CG
BlahBlahBlah
Interesting stuff to know thanks. I figured worst case scenario I have a complete extra set of NOS hub assembly's for my 71 K20 that I never used just in case I end up forking stuff up lol.
Old 11-16-2010, 08:46 PM   #15
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
this is good to know I was thinking about this a while ago. I didn't want to have to get in and out to lock and unlock my hubs. Thanks for all the info.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
